dual EFI entries after GPT conversion
2023-02-18T01:49:50+00:00
For reasons too lengthy to detail here, I was unable to use MBR2GPT for converting my current boot disk. Instead, I used Hasleo Disk Clone to clone the disk to another SSD while also converting it to GPT. This worked fine and the new drive correctly shows up as GPT with the shiny new MSR and EFI partitions. However, it left the protected/system EFI directory intact on the drive. My UEFI has been set to UEFI only with CSM=Disabled and yet I can still see entries for both EFI instances. Booting to the GPT partition works fine, but booting to the EFI directory fails. Is it possible (and safe) to either archive/rename or delete the EFI directory on C:\ so that it is no longer detected by the UEFI and disappears from the boot menu? I'm loathe to take any of the additional steps towards a Win11 upgrade without sorting this out first.
2023-03-07T05:38:10+00:00
(1) Even looking at the log, I'm unsure what's up with /SetREImage. But I think it is unnecessary. We'll revisit it if necessary.
(2) It looks like /Disable followed by /Enable would get the job done all by themselves. /Disable moved WinRE.wim from partition 3 into the staging area, namely C:\Windows\system32\Recovery....
2023-03-06 17:24:41, Info [ReAgentc.exe] winreCopyWIMBack moved WIM file from \?\GLOBALROOT\device\harddisk3\partition3\Recovery\WindowsRE\ to C:\Windows\system32\Recovery\Winre.wim successfully!
Then /Enable wanted to move it into partition 4, which it did recognize to be the Recovery partition. But it found that partition to be too small...
2023-03-06 17:24:49, Info [ReAgentc.exe] Checking partition at offset 497942528000, partition number: 4
2023-03-06 17:24:49, Info [ReAgentc.exe] MeetPartitionRequirements Partition details: {Offset: 497942528000, Free space: 467849216, Total space: 487256064}
2023-03-06 17:24:49, Info [ReAgentc.exe] MeetPartitionRequirements WinRE WIM size: 423565200
2023-03-06 17:24:49, Info [ReAgentc.exe] MeetPartitionRequirements Required free space: 478091152
2023-03-06 17:24:49, Warning [ReAgentc.exe] MeetPartitionRequirements Not enough free space req = 478091152 avail = 467849216 offset = 497942528000
2023-03-06 17:24:49, Info [ReAgentc.exe] skip partition because it does not meet WinRE requirements
(3) So, let's make it bigger. Mine is 848 MB. Your Disk Management (DM) shows the Recovery partition of 465 MB is followed by 1.56 GB of unallocated space...
Unfortunately, DM won't let you make it larger because it is a system partition. Can you easily add 383 MB to it using AOMEI Partition Assistant? If not, we can try this...
DiskPart <<<Enter DiskPart
Select Disk 3 <<<Focus on the EVO 970
List Part <<<Show its partitions
Select Part 4 <<<Focus on its Recovery partition
Detail Part <<<Show it has the Recovery type code
SET ID=ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 Override <<<Basic Data Partition
Detail Part <<<Show the new type code
Exit <<<Leave DiskPart
The 2nd Detail Part should show the new type. It is now a Basic Data Partition. Reboot to be sure the whole system knows. Then open Disk Management, right-click what was the Recovery partition, & see whether you can extend volume to 848 MB. Then make it a Recovery partition again this way...
Select Part 4 <<<Focus on what was its Recovery partition
Detail Part <<<Show it has the Basic type code
SET ID=de94bba4-06d1-4d40-a16a-bfd50179d6ac Override <<<Recovery Partition
I would Reboot again. Then, try...
ReagentC /Disable
ReagentC /Enable
ReagentC /Info
I hope that will do it. Good luck.
2023-02-23T12:27:49+00:00
(1) This should move {bootmgr} back to the top of DisplayOrder...
BCDEdit /Set {FWBootMGR} DisplayOrder {BootMGR} /Addfirst
That is where it belongs. I don't know how it got to the bottom. Do a full reboot for it to register in BIOS. Then, show us a new BCDEdit /Enum All.
That's nasty that BIOS adds one back after you have deleted it.
(2) The order of the GUIDs in DisplayOrder does not have to be the same as they are in the body of the BCD. In the body, they are in the order the boot entry was created. Moving one to the top of DisplayOrder should also move it to the top in BIOS Setup (after a full reboot). It then becomes the one that will boot by default. That is, it's the one that boots unless you chose another by using the one-time BIOS Boot Options menu. I think in your Asrock that is invoked with F11. (And DEL or F2 goes to BIOS Setup).
(3) I'm confused about your BIOS. I don't have one that complex.
(a) I don't know why it's got 4 Boot Options.
(b) Are you sure it is Boot Option #1 that is executing? Maybe disable ...#2 to be sure.
(c) Show us the contents of ...#2 as you showed ...#1 below.
(d) What is that item that is disabled within ...#1?
Our goal is to have you boot to the EVO that has Windows on it. So, that is the drive that needs to be at the top of the Boot Order in your Boot Option #1. Is it...?...
The way to know that it is the correct Windows partition that is booted is that your C: partition will be 463 GB...
Ramesh 181.7K Reputation points Volunteer Moderator
2023-02-23T03:26:03+00:00
Rebuilding the BCD should be enough, not the entire boot files, even though rebuilding the entire boot files doesn't do any harm.
And wondering why you're trying to create a Recovery drive with system files? Is it for backup/restore purposes or only for accessing WinRE? If it's for accessing WinRE, you can uncheck "Backup system files..." and create the media.
Regarding your question about C:\EFI folder, you can simply rename it. If Windows reboots correctly, that folder can be deleted. Do this only after creating the USB setup disk or Recovery drive.
56 additional answers
    2023-02-18T17:46:07+00:00
    I've attached both the disk and volume views from Disk Management as well as a view from the AOMEI tool since it also displays the MSR partition that's invisible to Disk Management. There's also a screenshot showing the legacy EFI "directory" on the boot drive that was previously used when the disk was MBR. This selection will no longer boot, but it shows up in the boot manager menu. It also seems to randomly shuffle the order of that boot menu any time I make a change to the BIOS. Even if I disable the boot entry for the MBR\EFI selection in UEFI, it still appears as an option during boot. This is what really drives me crazy since I can't tell which is the GPT/EFI and which is the MBR/EFI without attempting to boot. As a point of clarification, I intend to wipe the 850 to use as a single partition data drive once the 970 and BIOS are fully stable - so don't worry about its entries. (The diskpart command output is at the bottom of this post.)
    DISKPART> lis dis
    Disk ### Status Size Free Dyn Gpt
    Disk 0 Online 232 GB 51 MB *
    Disk 1 Online 1863 GB 1024 KB
    Disk 2 Online 232 GB 1024 KB *
    Disk 3 Online 465 GB 1600 MB *
    Disk 4 No Media 0 B 0 B
    Disk 5 No Media 0 B 0 B
    Disk 6 No Media 0 B 0 B
    DISKPART>
    DISKPART> lis vol
    Volume ### Ltr Label Fs Type Size Status Info
    Volume 0 D DVD-ROM 0 B No Media
    Volume 1 E DataDrive NTFS Partition 232 GB Healthy
    Volume 2 G Gaming NTFS Partition 1863 GB Healthy
    Volume 3 System Rese NTFS Partition 35 MB Healthy
    Volume 4 F NTFS Partition 232 GB Healthy
    Volume 5 FAT32 Partition 100 MB Healthy Hidden
    Volume 6 Recovery NTFS Partition 464 MB Healthy Hidden
    Volume 7 C NTFS Partition 463 GB Healthy Boot
    Volume 8 FAT32 Partition 100 MB Healthy System
    Volume 9 Recovery NTFS Partition 464 MB Healthy Hidden
    Volume 10 I Removable 0 B No Media
    Volume 11 J Removable 0 B No Media
    Volume 12 K Removable 0 B No Media
    DISKPART>
    DISKPART> sel dis 0
    Disk 0 is now the selected disk.
    DISKPART>
    DISKPART> det dis
    Samsung SSD 850 EVO 250GB
    Disk ID: {6A096C82-1A57-4D46-8170-7B205E80D36F}
    Type : SATA
    Status : Online
    Path : 1
    Target : 0
    LUN ID : 0
    Location Path : PCIROOT(0)#PCI(0102)#PCI(0001)#ATA(C01T00L00)
    Current Read-only State : No
    Read-only : No
    Boot Disk : No
    Pagefile Disk : No
    Hibernation File Disk : No
    Crashdump Disk : No
    Clustered Disk : No
    DISKPART>
    DISKPART> lis par
    Partition ### Type Size Offset
    Partition 1 Reserved 15 MB 17 KB
    Partition 2 Primary 232 GB 16 MB
    DISKPART>
    DISKPART> sel par 1
    Partition 1 is now the selected partition.
    DISKPART>
    DISKPART> det par
    Partition 1
    Type : e3c9e316-0b5c-4db8-817d-f92df00215ae
    Hidden : Yes
    Required: No
    Attrib : 0000000000000000
    Offset in Bytes: 17408
    There is no volume associated with this partition.
    DISKPART>
    DISKPART> sel par 2
    Partition 2 is now the selected partition.
    DISKPART>
    DISKPART> det par
    Partition 2
    Type : ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
    Hidden : No
    Required: No
    Offset in Bytes: 16777216
    * Volume 1 E DataDrive NTFS Partition 232 GB Healthy
    DISKPART>
    <<deleted - there are no partitions 3-6>>
    DISKPART>
    DISKPART> sel dis 1
    Disk 1 is now the selected disk.
    DISKPART>
    DISKPART> det dis
    Samsung SSD 870 EVO 2TB
    Disk ID: 415061BC
    Type : SATA
    Status : Online
    Path : 4
    Target : 0
    LUN ID : 0
    Location Path : PCIROOT(0)#PCI(0102)#PCI(0001)#ATA(C04T00L00)
    Read-only : No
    Boot Disk : No
    Pagefile Disk : No
    Crashdump Disk : No
    Clustered Disk : No
    DISKPART>
    DISKPART> lis par
    Partition 1 Primary 1863 GB 1024 KB
    DISKPART>
    DISKPART> sel par 1
    DISKPART>
    DISKPART> det par
    Partition 1
    Type : 07
    Hidden: No
    Active: No
    Offset in Bytes: 1048576
    * Volume 2 G Gaming NTFS Partition 1863 GB Healthy
    DISKPART>
    <<deleted - there are no partitions 2-6>>
    DISKPART>
    DISKPART> sel dis 3
    Disk 3 is now the selected disk.
    DISKPART>
    DISKPART> det dis
    Samsung SSD 970 EVO 500GB
    Disk ID: {A7153D34-52E7-4173-87AE-1C01624EA161}
    Type : NVMe
    Status : Online
    Path : 0
    Target : 0
    LUN ID : 0
    Location Path : PCIROOT(0)#PCI(0106)#PCI(0000)#NVME(P00T00L00)
    Read-only : No
    Boot Disk : Yes
    Pagefile Disk : Yes
    Crashdump Disk : Yes
    Clustered Disk : No
    DISKPART>
    DISKPART> sel par 1
    DISKPART>
    DISKPART> det par
    Partition 1
    Hidden : Yes
    Required: No
    Attrib : 0X8000000000000000
    DISKPART>
    DISKPART> sel par 2
    DISKPART>
    DISKPART> det par
    Partition 2
    Type : c12a7328-f81f-11d2-ba4b-00a0c93ec93b
    Hidden : Yes
    Required: No
    Offset in Bytes: 135266304
    * Volume 8 FAT32 Partition 100 MB Healthy System
    DISKPART>
    DISKPART> sel par 3
    Partition 3 is now the selected partition.
    DISKPART>
    DISKPART> det par
    Partition 3
    Hidden : No
    Required: No
    Offset in Bytes: 240123904
    * Volume 7 C NTFS Partition 463 GB Healthy Boot
    DISKPART>
    DISKPART> sel par 4
    Partition 4 is now the selected partition.
    DISKPART>
    DISKPART> det par
    Partition 4
    Type : de94bba4-06d1-4d40-a16a-bfd50179d6ac
    Hidden : Yes
    Required: No
    Offset in Bytes: 497942528000
    * Volume 9 Recovery NTFS Partition 464 MB Healthy Hidden
    DISKPART>
    DISKPART> sel par 5
    The specified partition is not valid.
    Please select a valid partition.
    There is no partition selected.
    DISKPART>
    2023-02-18T02:09:21+00:00
    Please perform the following steps:
    1. Post an image of disk management:
    (by default rows and columns are compressed and characters are cutoff)
    a) Widen rows disk 0, disk 1, disk 2, etc. > make sure that no characters are cutoff
    b) Widen columns Volume and Sources > make sure that no characters are cutoff
    https://www.tenforums.com/tutorials/2503-how-post-screenshot-disk-management.html
    1. Open administrative command prompt and copy and paste: (all at one time)
    bcdedit
    reagentc /info
    diskpart
    lis dis
    lis vol
    sel dis 0
    det dis
    lis par
    sel par 1
    det par
    sel par 2
    det par
    sel par 3
    det par
    sel par 4
    det par
    sel par 5
    det par
    sel par 6
    det par
    sel dis 1
    det dis
    lis par
    sel par 1
    det par
    sel par 2
    det par
    sel par 3
    det par
    sel par 4
    det par
    sel par 5
    det par
    sel par 6
    det par
    sel dis 3
    det dis
    lis par
    Type:
    ctrl + a
    ctrl + c
    Paste into this thread typing:
    ctrl + v
