Updating the Killer app to latest version does not fix the issue. I found this article https://www.intel.com/content/www/us/en/support/articles/000058906/wireless/wireless-software.html and discovered that doing the manual uninstall steps of the clean install instructions fixed it permanently. Remove and do not reinstall the Killer app. Of course, as we all know individual results may vary so please don't flame me if it doesn't work the same for you :D
Works fine with this Killer version 3.1423.302.1 as long as Killer Prioritization Engine is set to Off. 🤷♂️
I did not need to uninstall or do any other settings change. 😉
