How do i fix no audio device installed in windows 11?
2023-04-13T09:45:51+00:00
ive tried troubleshooting but it couldnt identify the problem
ive also tried rebooting my device
i also cant update my high definition audio device which i want to use because the other one doesnt work too(windws encountered a problem installing the drivers for your device code 10)
my other audio driver is working fine but still it says no audio device installed(this audio driver is the one written in japanese)
ive also came to the intel website to look up for my drivers but it says its up to date
    2025-06-02T17:56:28+00:00
    My laptop all of sudden says "no audio device installed" and no sound is playing i dont know what to do
    2025-06-17T16:34:30+00:00
    I am using HP Laptop. My sound all at once says there is no sound installed. A mystery why!!
    Teresa
  3. VARADHARAJAN K 9,726 Reputation points Volunteer Moderator
    2025-06-18T08:58:12+00:00
    Send your audio chip hardware device id
    2025-06-25T14:49:07+00:00
    best audio drivers
  5. VARADHARAJAN K 9,726 Reputation points Volunteer Moderator
    2025-06-25T16:13:52+00:00
    What do you mean by that
