I'm asking how did Windows 11's install program get on your flash drive. Did you get a new install from Microsoft, in which case it could be different from the one we've all been suffering which originated from a notification by MS to upgrade from Win10 to Win11.
How do i fix no audio device installed in windows 11?
ive tried troubleshooting but it couldnt identify the problem
ive also tried rebooting my device
i also cant update my high definition audio device which i want to use because the other one doesnt work too(windws encountered a problem installing the drivers for your device code 10)
my other audio driver is working fine but still it says no audio device installed(this audio driver is the one written in japanese)
ive also came to the intel website to look up for my drivers but it says its up to date
2024-09-05T21:11:24+00:00 -
2024-09-05T22:54:12+00:00 Hello! Yeah, i understand what you are saying now. My issue started on my Windows 11 OS. I specifically believe it was an update from Avast that caused my issue. As soon as Avast updated my drivers and the computer restarted, The No Audio Device Detected message appeared.
I had to do a hard format of my hard drive.
To answer your questions specifically,
- I got a 32 gb flash drive and converted it into a bootable flash disk. To see how i did this Create a bootable USB flash drive | Microsoft Learn
- Next i use the microsoft media creation tool to copy the windows install program from the microsoft website into the flash drive Download Windows 11 (microsoft.com)
- Finally i changed the boot order on BIOS making the flash drive 1st priority so the computer boots from my flashdrive. This was how i did a clean install of windows 11 and my audio drivers came back!
2024-09-06T18:45:08+00:00 Got it. You fortunately downloaded a debugged version of the Win11 Install. I would follow your procedure except for the part where you formatted the entire drive. That may be the crucial step but I have too many apps and stored files on that computer to do that. So, thanks for your postings but I think I'd best just keep on suffering the lack of sound that was seemingly caused by a Microsoft update. Its more of an archival PC anyway, not my day-to-day separate computer on which I am ardently hanging on to Win10 that works a lot better for me than Win11 anyway.
2024-09-10T03:44:20+00:00 I just purchhased a new laptop 3 weeks ago and the issue is still ongoing. I've lost all audio capabilities after doing updates,
2024-09-10T15:32:22+00:00 Aint that nice! 😣😣😣
My next computer is going to be a Mac or anything that does not require any version of Windows OS .
I feel like Microsoft has committed operational suicide possibly via warped hiring practices.
