Same problem with my l logitech 920-cam.
Suggested fixes didn’t help, only to restart without cam connected and not re-connect it, once I connect it, audio/sound is lost.
It says no audio device is installed when I plug in my c920 logitech camera. This just happened recently. They used to work well together before.
go under device manager, scroll down to "Sound, video and game controllers" disable device "1080P Pro Stream" under THIS category but leave it enabled elsewhere. Instantly all my other audio inputs kicked back on
This works but the mic of the webcam doesnt work because its been disabled.
Is microsoft even looking into this ?
Works for me, but as previous stated web-cam mic is deactivated so you need to keep your laptop close. Thanks.
I tried both uninstalling and disabling the device under "Sound, video and game controllers" and still seeing Windows Audio service stopping when connecting my Logitech webcam (mine is C910). Also tried that on the other devices associated with the webcam (e.g. mic under "Audio inputs and outputs" and camera under "Camers") but still seeing Windows Audio stopping.
I did however find a solution that isn't ideal but workable: install Logitech Capture.
https://www.logitech.com/en-us/software/capture.html
The not so ideal part:
