It says no audio device is installed when I plug in my c920 logitech camera
2023-07-09T11:31:01+00:00
It says no audio device is installed when I plug in my c920 logitech camera. This just happened recently. They used to work well together before.
    2023-11-02T18:37:31+00:00
    Please see this page for a solution. I can confirm it works for solving the issue with a c920 on Windows 11.
    2023-11-03T07:51:15+00:00
    Thanks, this seems to work. I have not dared to reboot the system yet :)
    2023-11-10T16:12:23+00:00
    This worked for me as well. Not to forget to go to services and start the 'Windows Audio' service
    2023-11-13T10:06:56+00:00
    this fixWorked for me
    2023-12-03T23:25:37+00:00
    I can confirm I have just done this (with a C922 pro) and it seems to be a fix.
    To give more context from my limited understanding: something in the webcam settings interferes with the Windows Audio service, which shuts down. I have done a LOT of messing about with drivers, switching the normal speakers and mic to "generic software device" and uninstalling, disabling and reinstalling the webcam drivers. It is possible to get a temporary fix this way, but every time you restart, you will have to go through the process again.
    The key part from the solution linked above is turning off the sound enhancements in the webcam. All of the rest is clever work with the Windows Audio service to get it to appear so you can change that setting. Now the drivers for the webcam and the other devices don't clash, and the Windows Audio service is running fine.
    Ironically, I started having this issue when I got a new laptop. The old one was a HP Omen running Windows 11. The new one is also a HP Omen running Windows 11, but a faster, newer, shinier version. This would seem to be an easy fix for Logitech if they could switch off the sound enhancements as default.
