I'm having the same problem.
Wating too
It says no audio device is installed when I plug in my c920 logitech camera. This just happened recently. They used to work well together before.
Wating too
Ok. Thanks. I'll wait.
I'm afraid I'm running out of ideas. Let's ask other advisors.
They will reply on this thread. I'm sorry I could not help much.
Your patience will be highly appreciated.
Thanks for your reply.
Unfortunately those methods don't work. But I'm sure that the problem is with the Windows Audio service. Whenever I start the service, it stops immediately. But when I unplug my camera it starts again. Could you please tell me how to fix this?
Hello, My name is Erfan. I will help you with this.
I understand how frustrating it is. Please try the below steps.
Unplug the webcam and plug in another USB port.
Reinstall driver
Restart Audio Services
Check for Windows updates. Settings(Win+I) > Windows update > Check for Windows update.
After installing the pending updates and restarting the computer, return to the exact Windows Update screen, click Advanced Options > Optional Updates, apply the optional updates, and restart the PC.
Let me know if that did not help. Thank you.
