Virtual Network Adapter
2023-09-05T20:16:55+00:00
My Windows 11 laptop will no longer connect to Wi-Fi. It says "You're connected using a virtual network adapter that we can't test." I have restarted my laptop and rebooted the modem, neither worked. Any help on what to do next?
    2024-02-25T20:02:28+00:00
    I have had this problem several times and had a Microsoft technician fix it, unsatisfactory, the first time. It seems to occur when my HP laptop is left on but sleeping. It corrects itself when the laptop is shut down snd and disconnected from the power supply for an extended period.
    2024-02-25T20:06:21+00:00
    I have had this problem several times and had a Microsoft technician fix it, inadequately, the first time. It seems to occur when my HP laptop is left on but sleeping. It corrects itself when the laptop is shut down snd and disconnected from the power supply for an extended period.
    2024-03-07T13:06:12+00:00
    Yes wifi problem in our laptop
    1.
    2024-03-13T13:56:54+00:00
    This worked perfectly!!! Thank you so much for taking the time to post this, step by step.
    It helped immensely! Same as you, I also didn’t have to restart my computer.
    Thanks again!
    2024-03-16T19:17:10+00:00
    This solution worked for me. Thanks.
