I do not see an error page on the new account, but when I switch back to the old one, where my bitlocker keys are supposed to be, I get the error again. Very annoying. Still locked out of my new laptop. Amazing.
Can not get my BitLocker recovery key
When going to https://account.microsoft.com/devices/recoverykey to get the BitLocker recovery keys of my device, I get an error saying:
"Sorry, something went wrong.
We're not sure what happened but refreshing the page may help, or try again in a little while.
TraceId: lBgh0JGs40W+tj6N.30.98"
Same thing when I would go to https://account.microsoft.com/devices and then click on "info & support" on my device that I need to recover after blue screening and then "Manage recovery keys", which basically takes me to the link mentioned at the top of this post.
This is very frustrating as I can't start working with my brand new laptop that just crashed on me from day 1.
Any reply from people trying if that link works for them is appreciated.
Windows for home | Windows 11 | Recovery and backup
2023-09-17T20:04:52+00:00 -
2023-09-17T20:21:14+00:00 I tried the mentioned workaround twice. Making two new accounts. Making the second account I did incognito in chrome without any add-ons enabled. Maybe it was luck, or maybe it affects the outcome. Not sure. But I have my keys now.
2023-09-17T21:07:37+00:00 Experiencing the same issue here, going to be saving to my password manager Bitwarden and adding name tags as I dualboot Windows 10 and 11 and also have a MIni PC as my desktop which also has Bitlocker.
2023-09-18T17:00:35+00:00 Same, since my computer automatically updated on the 15th, I have been unable to obtain the recovery key.
What makes me even more anxious is that the locked device was my working computer. I thought Microsoft would solve it soon but it's already Monday and they still haven't. I was forced to ask my boss for a day off because all the data was in the locked computer and I basically can't work.
2023-09-18T19:41:12+00:00 After replacing my motherboard, I encountered the same issue when trying to access: https://account.microsoft.com/devices/recoverykey.
These are the steps I took to resolve this:
- Open Microsoft Edge
- If signed into MS Edge; clear your Microsoft Live password by opening your Edge Profile, and clicking the gear
- Scroll down to Passwords, under the Saved Passwords section, find and select the login.live.com entry and any other MS Login (put a checkmark in the box to the left of each one).
- Click the Delete button
- Close and reopen Edge
- Enter https://account.microsoft.com/devices/recoverykey in the Edge address bar and press enter
If it worked, you're done... If the issue persists, continue below:
- If signed into MS Edge, sign out by clicking your Profile, click the gear, and click the Sign Out button
- Click the box for "Clear Favorites, History, ..." (You should have a check in the box)
- Click the Sign Out button
- This should restart Edge automatically with a default profile (check to be sure by clicking the profile icon at the top right)
- At the top right of Edge, click the three dots "...", and select History
- Click the trash can icon at the top, select All Time from the drop-down, and place a checkmark in every box available (you have to scroll down to see them all)
- Click the Clear Now button
- Enter your MS credentials; select No, thanks if asked to sync data
- Click add account (even if yours is already there), and sign in
If it worked, you're done... If not, I successfully applied a similar strategy using Firefox. Give it a try. Good luck.
