Why these steps are not working . I awaiting for your reply. Thanks.
How to Unlock a Device Locked Using Find my Device in the Microsoft Account
I have a Windows 11 laptop. I inadvertently locked the laptop when I logged into my Microsoft Account and it showed the device was located in a different part of the Country from where I am located. After locking the device, I realized it was my personal laptop (in my possession, not where it was shown to be on the map). I am now trying to unlock it but cannot locate anywhere in my online Microsoft Account where to do so. My user pin and fingerprint aren't being recognized. Can anyone help?
Windows for home | Windows 11 | Accounts, profiles, and login
2024-07-10T13:14:35+00:00 -
2024-07-12T17:30:36+00:00 After entering the 1234 password to load hive, an error message popped up stating " cannot load (location): process cannot access the file because it is being used by another process.
What's the next step?
2024-07-24T17:25:35+00:00 Not a software engineer, just a frustrated fellow with too much time on his hands...
1 & 2: Window beside file directory is how I describe the area to the right of the folders you were navigating through. Just the area where files contained within the folder appear, I just can't think of another way to describe it. Open to suggestions. DevicePassword... was an oversight on my part, same thing.
3 & 4: Nothing needed post fix. That value will change depending on the method you've picked to sign into the computer, whether password or pin. Setting it to 0 forces the computer to use microsoft login.
2024-07-24T17:29:15+00:00 I'm not sure, my apologies. Maybe I should preface the solution with it working on Windows 11. Looks like you are using an older version, 7 perhaps? I wouldn't expect that to make or break the solution, but I'm also not an expert.
2024-07-28T06:38:45+00:00 Just following up in case anyone encounters the issue again, I was unable to login to my computer after accidentally locking my own desktop as I thought I was locking a suspicious device, I canceled the locking process (thought i did) but a day after I did so the computer was locked with the message I wrote when locking it, when logging in it said, administrator access is required to log in, but I am the administrator of my computer, I changed the sign in option to password instead of my 4 digit pin and it worked and let me in, I had to reset my pin afterwards for it to work again but it did work and I didn't have to reinstall, you need to use your windows password not windows hello/pin
