Monitor settings randomly change
2024-03-05T20:57:44+00:00
I've been experiencing an issue with my Philips monitor where the SmartImage feature unpredictably switches to "Racing" mode on its own. Despite manually disabling this setting, it often reactivates itself multiple times until it finally remains off, only to recur upon restarting my PC or monitor. This problem emerged just last week, despite my having used this new PC and monitor setup for nearly a year without any similar issues. I've meticulously reviewed most of the accessible settings without identifying any that could be causing this behavior. Additionally, I've explored the monitor's on-screen menu but found nothing that explains the automatic switch to "Racing" mode, leading me to suspect it might be related to a setting on my PC. However, I've yet to pinpoint exactly what could be triggering this. If anyone has insights or suggestions on how to resolve this, your advice would be immensely valuable. Thank you in advance for your help.
    2024-05-23T09:20:11+00:00
    Michael, my attempt to report the issue to HP ends in the following: "We are convinced it's a problem with the monitor. We can reset you laptop to factory defaults which will erase all data from your system".
    As a former HP employee I have serious problem with such a statement. I might try another equivalent laptop (my wife has one too - exactly the same) to see if the problem occurs also when I connect the {Philips monitor).
    For the time being I consider not to install updates from HP Inc. - SoftwareComponent through Windows Updates optional software until HP releases another version of their hp-telemetry-peripheral-collector. Or alternatively keep changing names of hp-telemetry-peripheral-collector_ver_3.0.4737034
    2024-05-23T09:37:25+00:00
    I can confirm that changing the folder name resolved the problem for me as well. This is definitely not a hardware issue.
    Really happy the problem has been fixed for now.
    2024-05-23T14:35:23+00:00
    OK, For those interested: During the past 48 hours exchanged information (through WhatsApp) with HP Customers Support. At some point I was trasferred from an AI agent to a human agent. I will spare you all the details but the call is closed now.
    Solution (actually a workaround it should be called) as per my suggestion change the name of the HP Telemetry Collectors directory (sorry I started with Unix in 1976) C:\ProgramData\HP\Telemetry\collectors\hp-telemetry-peripheral-collector_ver_3.0.4737034 to something different. In that way no other process will start any .exe of .dll file in there. As a sidemark. Whenever you install an optional update from Windows Update named HP Inc. - SoftwareComponent xx.x.x, you better check the directory name. This happened to me earlier this week and the 'racing mode' was back again case the entire directory came back on my system
    I was triggered by the following error messages in one of the logfiles:
    Error :VcpCodeDataHandler::GetValueFromVcp - Failed for the Command :20 in Normal format
    Error :VcpCodeDataHandler::GetValueFromVcp - Failed for the Command :220 in Normal format
    Error :VcpCodeDataHandler::GetValueFromVcp - Failed for the Command :229 in Normal format
    I assumed that the HP Telemetry software made changes to the VCP data inside the monitor.
    Searching the internet I found an application by Nirsoft named ControlMyMonitor and I installed the most recent version 1.38. The application lets you read (and wirte) from the monitor the VCP values. You'll find the software at the Nirsoft website www.nrisoft.net (https://www.nirsoft.net/utils/control_my_monitor.html to be more precise!)
    Since my monitor stays now in the SmartImage off mode I could save the config easily as Ascii. Then I switched the monitor manually to the 'racing mode' and saved that configuration also in Ascii. After some editing of the output files I found the differences for SmartImage off and SmartImage racing to be:
    VPCCode 0C 'Color Temperature Request' 63 versus 35
    VPCCode 14 'Select Color Preset' 8 versus 11
    VPCCode 16 'Video Gain (Drive): Red' 100 versus 86
    VPCCode 18 'Video Gain (Drive): Green' 100 versus 94
    VPCCode 72 'Gamma' 160 versus 128
    VPCCode 86 'Display Scaling' 160 versus 120
    VPCCode DC 'Display Application' 0 versus 6
    VPCCode EF 'Manufacturer Specific' 255 versus 1
    VPCCode F0 'Manufacturer Specific' 1 versus 0
    And then some testing. Changing VPCCode CC 'OSD Language' from 20 into 1 gave me English versus Dutch. Then going after VPCCode DC and changing it from 0 to 6. Yep into racing mode.
    Maybe if someone at HP Inc reads this, it might give them some directions. I am not an expert in VPCcode. However I found that ControlMyMonitor gave some text in a file I save. However I guess that each character came as a 16bit quantity. Once I removed the non-printable and 0 characters I could use the Unix diff command. Quiet a journey so to speak.
    2024-05-23T16:00:03+00:00
    As a former HP employee I have serious problem with such a statement. I might try another equivalent laptop (my wife has one too - exactly the same) to see if the problem occurs also when I connect tje {Philips monitor).
    Everyone in this thread has a different HP make/model and a Philips monitor. We've more than proven that this HP-Philips combination is toxic and doesn't (through lack of complaints) extend to non-HP devices. The proximity of this issue to the HP update, coupled with our ability to resolve the issue by manually disabling the HP update, only solidifies this conclusion.
    If HP is suggesting that all Philips monitors are suddenly "defective" because they do not operate properly with HP's new software, then that is simply short-sighted and ridiculous.
    2024-05-27T15:23:57+00:00
    I've been experiencing the same problem for several weeks now. I've had my HP Envy and Philips 28E2 monitor for several year with no issues until recently.
    I tried turning Bluetooth off and on as you did and got the same response - cycling caused my monitor to cycle between my settings an gamer 1 option. I went to the Bluetooth devices window and noticed that when I turn Bluetooth on I get a notice of "generic monitor (PHL 288E2)" as an available device in the Audio section. Since the monitor does not have speakers I quickly selected "remove device" and the screen cycling did not occur.
    Hope this observation helps in some way.
