Hi Aurora Yumeno,
Welcome to Microsoft Community.
Based on the information you have provided, your speculation is a higher probability.
Would you mind sharing more information about this issue with us?
- Were there any special events in the device before the problem occurred? For example, system update, driver update, application update, BIOS update?
- Is the situation the same if you start Windows with a more basic system setup (for example, Safe Mode)? Start your PC in safe mode in Windows - Microsoft Support
- When the phenomenon occurs, are there any event logs recorded on the system that may be close to the point in time of the phenomenon? Event Viewer | Microsoft Learn
- If possible, is the situation the same after you perform a clean uninstall and reinstall of the driver? This is not limited to graphics drivers; testing the monitor's drivers as well as the firmware may also be an option worth considering.
- If possible, is the situation the same when you connect the monitor to other Windows devices?
For graphic card devices, content in the following links mentioned the tool to clean up the graphics drivers.
| Disclaimer*: Microsoft provides no assurances and/or warranties, implied or otherwise, and is not responsible for the information you receive from the third-party linked sites or any support related to technology.* |
- Wagnard Tools (DDU,GMP,TDR Manipulat | NVIDIA GeForce Forums
- How to Use the Display Driver Uninstaller (DDU) to Uninstall an... (intel.com)
If I misunderstand your situation, feel free to correct me and share the information.
Best Regards,
Kyo - MSFT | Microsoft Community Technical Support
