which printers are compatible with Surface pro 11
2024-07-05T17:40:52+00:00
Specifically. which HP printers are compatible with SP11?
    2025-05-28T15:02:10+00:00
    Angela, a workaround I use is the Cannon Print app on the phone and print from the OneDrive wireless.... I'm not using the Surface Pro, though I can print.
    2025-05-29T18:02:33+00:00
    I have tried 2 different Epson home printers with my Surface Pro 11 but can't print with either.
