how do i fix my wifi/drivers problem and Bluetooth
2024-07-28T07:48:28+00:00
i just built my pc and i got a pc protector app I'm not really sure what is was called but it installed a Wi-Fi driver for my pc before i could not use Wi-Fi only ethernet and when i tried to download my motherboard drivers it installed but it didn't change any thing i tried a lot of different ways for the drivers to work but not a single way worked anyways i have Wi-Fi now but it cuts out a lot when I'm playing a game or just idle and it happens mostly when I'm playing a game ere and i want to fix this but i don't know how to if someone could help me id really love that here my specs B650 Aorus Elite Ax AM5 motherboard CPU Ryzen 5 7600x operating system windows 11 home and also i can't connect any Bluetooth devices to my pc
    2024-07-31T09:09:28+00:00
    this is everything is see
  2. DaveM121 936.1K Reputation points Independent Advisor
    2024-07-31T09:20:10+00:00
    The Bluetooth drivers are still not installed, the best option would be to contact the support for your system on their website to see if they have another available version of the drivers.
    2024-08-01T03:04:36+00:00
    i tried to contact my motherboard manufacture but they were unavailable should i wait for them to be available or what should i do
  4. DaveM121 936.1K Reputation points Independent Advisor
    2024-08-01T06:08:52+00:00
    If you have installed the only version of the Bluetooth drivers they provide, it would be best to wait for their support because there is no indication of what type of Bluetooth chip is on that motherboard.
    2024-08-01T06:40:23+00:00
    ok ill wait until they are available and i will update you if anything happens and thank you a lot for helping me!
