Solution for: Epson scanner no longer works after Windows 11 update
2024-07-03T20:40:15+00:00
Resolved for me, want to share with the Community:
Forget about the Epson interface and instead download and use the "Windows Scan" app here:
https://apps.microsoft.com/detail/9wzdncrfj3pv?amp%3Bgl=US&hl=en-u.s&gl=US
Once I did that my Epson DS-510 started working again. You select what device you want to use, either printers or scanners. Your scanner should appear in the dropdown list if is connected.
Some history: I had updated to Windows 11 in November 2023, and for about half a year I was able to use the DS-510 like previously. My Epson DS-510 mysteriously stopped working in May-June of 2024. In that timespan I had installed some Windows 11 updates.
Today I spent over 1 1/2 hours on the phone with Epson support and they tried to help but couldn't figure it out. Also in the course of that call we came across an option to use a Microsoft scanning app "Windows Scan," but the Epson tech said to ignore that and kept looking for other solutions.
Finally one of them said why don't you call Microsoft? It seemed to make sense to me that the problems was related to the Windows 11 update in May-Jun, since that coincided with the Epson no longer working. Then suddenly I said to myself why not at least try the Windows Scan app, and that turned out to solve the problem!
**** Moderator note: Converted to discussion
    2025-02-13T13:07:50+00:00
    So, after all this discussion, IS there a solution to the problem of scanning 6x6 negatives? Has someone come up with a real fix for the problem?
    Or are we in the Pass-the-Buck game where Microsoft says it's Epson's fault, while Epson says it's Microsoft's fault, and neither one will accept the responsibility to correct the problem?
    Has anyone found the proper app, or the proper fix of existing apps, to allow my to scan all my 6x6 negatives, or should I just consider using my V600 as a boat anchor?
    Why, after all this time, does not Epson exercise some true customer support and have its techs just fix the problem, once and for all?
    2025-02-14T16:35:25+00:00
    I want to know why WINDOWS would update ANYTHING that would interfere with personal property! I do not use my Epson or computer for anything but MY personal matters and now I can't scan and send anything to my attorneys because Microsoft took it upon themselves to add this "security feature" and I am no longer able to use a PRINTER/SCANNER that I paid for! And just where do I find this WINDOWS SCANNER app so I can get my crap done!?
    2025-02-14T20:36:10+00:00
    Hallelujah! That finally did the trick after hours of searching for a solution... grrrr. Thank you!
    A recent Windows 11 also caused my Epson vscan software to not be able to find my Perfection V600 scanner. After lots of searching I figured out this was caused by Microsoft automatically starting the 'Windows Image Acquisition' service. Here is how you can stop the service and set it to manually start.
    1. Search the start menu for Services
    2. Start the application
    3. Scroll down and double-click Windows Image Acquistion from the list of services
    4. Click the Stop button
    5. Set the Startup type: drop-down list to Manual
    6. Click the Apply button
    7. Click the OK button
    8. Exit the Services application
    2025-02-14T22:33:08+00:00
    I would love to say this worked, but no.. nothing!
    I have a Perfection V370.. after the last Windows update the old software stalled when it got to the "scan" stage.
    I have downloaded the latest version of Epson Scan which does work, connecting to the scanner and performing a preview, but then hangs when you press either the scan or the file location button...
    It looks like something does not have write permission, but I don't seem to be able to change much..
    WHY does this happen on Fridays?
    2025-02-14T22:43:39+00:00
    Wonder upon Wonders...
    I went to the Configuration button... selected "other" and pressed Reset All..
    .. All is reset and working!
    Whew!
