I do not see any problem indicated with your system now, if you are still having problem with Blender, it may be best to contact Blender support on their website, that may have a patch available for that software.
Need Help with BSOD Issues on My PC - Mostly Occurs with 3D Software
I’m not very knowledgeable about computers, so I’ve tried to describe the issues I’m facing as thoroughly as possible. I’m encountering BSOD problems, and they seem to be mostly related to 3D software, though I’m not entirely sure if it’s limited to just that.
For example, I have never had any issues running heavy tasks on Adobe programs like After Effects, Photoshop, or Premiere Pro, even when using them simultaneously. However, with Blender (version 4.1) and Unreal Engine (version 5.4), BSODs occur unpredictably.
In Blender, if I try to render using the CPU, I get a BSOD almost immediately (rendering with the GPU often causes the program to crash, but without a BSOD). Even during simple tasks, the program crashes or shows a BSOD at intervals ranging from as short as 5 minutes to several hours.
Unreal Engine sometimes triggers a BSOD right after launching, and I’ve noticed occasional crashes when running 3D games as well.
I’m not entirely sure if the problem is only with 3D software, so I really need help figuring this out.
Here are my computer specs:
- Motherboard: MSI MAG Z790 TOMAHAWK WIFI
- CPU: Intel i7-14700K
- Graphics Card: Gigabyte RTX 3060 Gaming OC 12G
- RAM: Corsair Vengeance DDR5 64GB (32 x 2)
I’ve attached the memory minidumps for reference. Any advice or help would be greatly appreciated.
my thoughts:
Maybe your 14700k is commiting suicide ( https://www.youtube.com/watch?v=swm7n88QmLA Related video)
Maybe you don't have drivers installed for your graphics card and CPU
You might want to check the Event Viewer app if you're using windows, This might add more detailed information about the crash
41 additional answers
2024-08-10T08:27:03+00:00 Thank you for the video, that ISO is not getting downloaded, if you have access to another PC, please try downloading the ISO on that PC to see if the donwload is successful.
2024-08-10T08:23:43+00:00 Here’s a video recording of the screen! Should I try downloading it on another computer and transferring it via USB to attempt the installation?
2024-08-10T08:07:40+00:00 That is the correct step, if open the downloads page in your browser, is that ISO downloading in the background?
