I do not see any problem indicated with your system now, if you are still having problem with Blender, it may be best to contact Blender support on their website, that may have a patch available for that software.
Need Help with BSOD Issues on My PC - Mostly Occurs with 3D Software
I’m not very knowledgeable about computers, so I’ve tried to describe the issues I’m facing as thoroughly as possible. I’m encountering BSOD problems, and they seem to be mostly related to 3D software, though I’m not entirely sure if it’s limited to just that.
For example, I have never had any issues running heavy tasks on Adobe programs like After Effects, Photoshop, or Premiere Pro, even when using them simultaneously. However, with Blender (version 4.1) and Unreal Engine (version 5.4), BSODs occur unpredictably.
In Blender, if I try to render using the CPU, I get a BSOD almost immediately (rendering with the GPU often causes the program to crash, but without a BSOD). Even during simple tasks, the program crashes or shows a BSOD at intervals ranging from as short as 5 minutes to several hours.
Unreal Engine sometimes triggers a BSOD right after launching, and I’ve noticed occasional crashes when running 3D games as well.
I’m not entirely sure if the problem is only with 3D software, so I really need help figuring this out.
Here are my computer specs:
- Motherboard: MSI MAG Z790 TOMAHAWK WIFI
- CPU: Intel i7-14700K
- Graphics Card: Gigabyte RTX 3060 Gaming OC 12G
- RAM: Corsair Vengeance DDR5 64GB (32 x 2)
I’ve attached the memory minidumps for reference. Any advice or help would be greatly appreciated.
my thoughts:
Maybe your 14700k is commiting suicide ( https://www.youtube.com/watch?v=swm7n88QmLA Related video)
Maybe you don't have drivers installed for your graphics card and CPU
You might want to check the Event Viewer app if you're using windows, This might add more detailed information about the crash
41 additional answers
2024-08-09T16:23:12+00:00 I successfully launched Unreal Engine after completely removing the XP-Pen driver. Thank you! The XP-Pen driver is necessary for using my pen display tablet, but does this mean I should avoid using it in the future?
Unfortunately, I’m still experiencing the same issues with Blender. I followed the process you initially provided in the same order and repeated it. Could you please check it again? I’m trying to determine whether this is an issue with Blender itself or something wrong with my computer. Here are the new dumps that were generated. New Dumps3
2024-08-09T15:45:17+00:00 Driver Verifier indicates it is a driver associated to an XP-Pen tablet that is causing your system to crash.
With regards to your Audio, that is not normal, go to the support page for your motherboard to download and re-install the version of HD audio drivers they provide.
2024-08-09T15:39:31+00:00 Sorry! There was an error. Here is new link: New Dumps2
Additionally, after following the above steps, I ran the commands
verifier /resetandverifier /bootmode resetonbootfail, then rebooted my computer. However, after rebooting, my audio output device has disappeared, and the computer is no longer outputting sound. Is this normal?
