I want to Reset my PC but keep my files & settings, how do I do it?
2024-09-20T20:06:06+00:00
i wish to Reset my PC because I'm having problems with the Touchpad and some windows closing sporafically. I have tried everything to resolve the Touchpad problem but it continues to not work, then work and it continues. The more fixes I try the worse it gets, I have had enough and have been told to revert to original settings. I used Reset on my 6 year old Windows 10 PC and it resolved problems I was experiencing.
I don't know how to do it on my Windows 11 PC and need so me help to get started. Are you able to help?
Windows for home | Windows 11 | Recovery and backup
Solamillo Charity 20,295 Reputation points Independent Advisor
2024-09-26T01:59:14+00:00
Thank you for getting back to me. Did it just stopped abruptly, or did it have any error codes?
Since you're considering sending the laptop for repair, it’s a smart move to back up everything you might need for a smooth transition.
I would suggest to check this one https://www.youtube.com/watch?v=bCTZ9tO_BtI
Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install.
Please let me know if you have any more questions, I'll do my best to respond as soon as possible.
49 additional answers
    2024-09-29T23:23:14+00:00
    See the prevous reply and the last question. I'm not happy that my One Drive dashboard is in File Explorer. Is there a way of making the folders in One Drive look different. I'm terrified I will mix them up. Most of the videos of One drive look very different.
    On this video, One Drive appears on the top left hand side of the screen. Is that the only screen for One Drive. If so, how do I find my File Explorer screen showing My C: drive and all the folders, files NOT in one drive.
