G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
2024-10-24T20:33:55+00:00
I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.
Here is what they said:
I understand your concern. I request you to contact Windows support as you are facing the issue after the Windows 11 update. There are high chances of audio drivers not updated properly. Hence, if you contact Windows support they will help you reinstall the software.
Please advise on how I should proceed, I've also linked a Reddit post with people having the same issue:
https://www.reddit.com/r/LogitechG/comments/1fml5oz/g_pro_x_wireless_plays_muteunmute_sound_when/
No one has found a solution yet
regards,
Taimur Ansari
2025-03-30T14:14:14+00:00
Fixed w/ KB5053656 3/27/2025.
78 additional answers
    2024-11-25T10:34:41+00:00
    I reinstalled my system yesterday and upgraded from Win 10 to Win 11. Now I have this problem with a freshly installed system that I didn't have before. Good job MS or whoever messed this up.
    Playing music on low volume works best for me right now as a workaround.
    2024-11-25T20:12:08+00:00
    A month has passed and the problem is still there. Upgraded to 24H2 today and felt it. Very annoying. When will there be a fix?
    2024-11-27T12:52:33+00:00
    hey! i've been having the same issue and this seems to fix it for me at least
    go to sound settings -> 'additional settings' at the bottom -> recording -> Logitech G Pro X Wireless Gaming Headset microphone -> Properties -> second tab -> check 'always listen from' and choose Logitech G Pro X Wireless Gaming Headset.
    and that's it , i got the solution from reddit https://www.reddit.com/r/LogitechG/comments/1fml5oz/g\_pro\_x\_wireless\_plays\_muteunmute\_sound\_when/.
    hopefully that helps :D!
    2024-11-29T07:29:26+00:00
    Thanks, but that means you'll hear what you say into the microphone. Only good for those who don't use a microphone.
