G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
2024-10-24T20:33:55+00:00
I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.
Here is what they said:
I understand your concern. I request you to contact Windows support as you are facing the issue after the Windows 11 update. There are high chances of audio drivers not updated properly. Hence, if you contact Windows support they will help you reinstall the software.
Please advise on how I should proceed, I've also linked a Reddit post with people having the same issue:
https://www.reddit.com/r/LogitechG/comments/1fml5oz/g_pro_x_wireless_plays_muteunmute_sound_when/
No one has found a solution yet
regards,
Taimur Ansari
2025-03-30T14:14:14+00:00
Fixed w/ KB5053656 3/27/2025.
78 additional answers
    2025-01-06T03:30:52+00:00
    This doesn't work for me, I only have 2 USB controllers that allow me to uncheck the box, but the beep still occurs. I've been using the service I wrote that generates a silent wave tone to keep the headset active and that's been working for me. I've been going back and forth between Logitech asking them to fix it, after 20 e-mails, they say they won't fix it and that Microsoft has to fix it, which is the stupidest **** answer I've ever heard, because Microsoft isn't going to fix it. So we're stuck with this ****.
    2025-01-06T23:00:50+00:00
    I tried it as well, and it didn't work for me.
  3. Deleted
    2025-01-11T11:17:52+00:00
    same problem on windows 11 pro 24H2. this is really annoying. I tried the last workaround showed here and still doesn't solve the issue. Please release a fix patch for this Microsoft
