G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
2024-10-24T20:33:55+00:00
I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.
Here is what they said:
I understand your concern. I request you to contact Windows support as you are facing the issue after the Windows 11 update. There are high chances of audio drivers not updated properly. Hence, if you contact Windows support they will help you reinstall the software.
Please advise on how I should proceed, I've also linked a Reddit post with people having the same issue:
https://www.reddit.com/r/LogitechG/comments/1fml5oz/g_pro_x_wireless_plays_muteunmute_sound_when/
No one has found a solution yet
regards,
Taimur Ansari
2025-03-30T14:14:14+00:00
Fixed w/ KB5053656 3/27/2025.
78 additional answers
    2024-10-25T06:20:03+00:00
    Hi Taimur Ansari,
    Welcome to Microsoft Community.
    Based on the original description, we understand that your device is experiencing frequent mute and unmute issues.
    The Logitech team gives a reasonable speculation that an anomaly in the driver's data state could be causing the strange issue.
    Unfortunately, we are in an online environment that does not have direct access to Reddit.
    If possible, would you mind sharing with us the critical information in the thread?
    If this issue appears after a Windows update, the first thing worth trying is to uninstall any recently installed updates.
    • Select Start > Settings > Windows Update > Update history > Uninstall updates.
    • On the list that appears, locate the update you want to remove, and then select Uninstall next to it.
    For drivers, you could try performing a clean uninstall/clean install of the driver if possible.
    The content in the links below described examples or tools related to this process.
    Disclaimer: Microsoft provides no assurances and/or warranties, implied or otherwise, and is not responsible for the information you receive from the third-party linked sites or any support related to technology.
    Disclaimer: Please back up all your important data before performing it.
    For the device itself, the state of its drivers or firmware may also affect the behavior of the audio drivers.
    If possible, you can try to restore the G Pro X Wireless itself to the default firmware state.
    If I misunderstand your situation, feel free to correct me and share the information.
    Best Regards,
    Kyo.Y - MSFT | Microsoft Community Technical Support
    2024-10-25T17:42:20+00:00
    No the device is not experiencing mute/unmute issues, it simply makes beeping sounds, while the audio is fine.
    2024-10-25T17:52:21+00:00
    Here is one guy's take on the matter:
    'Same issue. After updating to Win11 24h2, the headphones started making a mute/unmute beep. There is no beep on Win11 23h2. Reinstalling g-hub or removing drivers doesn't help. Even a clean reinstall of Win11 24h2 doesn't help (there is no beep on 23h2). It appears Microsoft broke something or altered how audio works with devices in 24h2.'
    He appears to have somehow fixed it later, he says,' Strangely enough, the problem solved itself. I don't know what helped. Maybe some small Windows updates after the 24h2 update.'
    Although I haven't found a fix yet myself.
    2024-10-25T18:50:21+00:00
    One of the workarounds mentioned in the thread worked for me - checking the 'Listen to this device' in additional sound settings(Microphone properties). I would still like a permanent fix, but no beeping for now at least!
    What do you think could be causing this issue considering this workaround worked?
