your good, thanks for helping, ima go get some rest on the couch before calling it a night, goodnight
switch pro controller not detected by pc on a new install
my pc (new install) doesnt detect my switch controller while wired, it doesnt make a noise when i connect it either, does anyone know why, usb port and cable are both fine as they worked before on my old install
2024-09-28T23:25:13+00:00 -
Solamillo Charity 20,295 Reputation points Independent Advisor
2024-09-28T23:30:50+00:00 Good night! If you find the answers above helpful, you may mark it as an answer. If not, please tap on "Reply".
2024-10-05T14:27:50+00:00 hey i know its been a while and you might not anwser, it just doesnt want to charge now, its working, it just doesnt charge via the pc, any idea why? its not that big of a deal as i can still use it... i did reinstall the drivers bc it fully stopped working but its back to working again, its just not charging... do you know how to fix this?
Edit: it doesnt charge at all anymore pc or not... it might just be full so ill play with it for a few hours to see if battery drains otherwise i guess my controller is just dead
