If your speakers stopped working after installing updates, it could be due to a driver issue or a configuration change. Here are some steps you can try to resolve the problem-
Check Sound Settings-
- Right-click the sound icon in the taskbar and select Open Sound settings.
- Make sure the correct output device (e.g., your speakers) is selected. If the wrong device is selected, click on the dropdown and choose the correct one.
Check Sound Enhancements-
- Right-click the sound icon in the taskbar and select Sounds.
- In the Playback tab, right-click your speaker and select Properties.
- Go to the Enhancements tab and check the box that Disable all enhancements. Sometimes, enhancements can interfere with audio output.
Run the Windows Troubleshooter-
- Press
Win + Ito open Settings.- Go to System > Troubleshoot > Other troubleshooters.
- Scroll down to Playing Audio and click Run. Follow the steps to diagnose and fix sound issues.
Update or Reinstall Audio Drivers-
- Press
Win + Xand select Device Manager.- Expand the Sound, video and game controllers section.
- Right-click on your audio device (e.g., Realtek or other sound drivers) and choose Update driver.
- If updating doesn’t work, try uninstalling the device and restarting your PC. Windows will automatically reinstall the driver.
Also, Go to Device Manager and check for other audio devices (e.g., HDMI audio) that may be set as the default. Disable any that aren’t in use, such as HDMI or Bluetooth, to force the system to use your speaker output.
Let me know if any of these steps resolve your issue!
no problmes soul
