Hi ,
Access the device manager in the other devices tab, take a screenshot and post it here.
After uninstalling anything related to Cirrus Logic and Driver Booster, if possible, use revo uninstaller.
Independent Advisor - Community
I've use driver booster 11 for my drivers and then it uninstalled all my sound driver and installed " Cirus Logic Awesome Speaker Amps and now my sound icon has a x besides it and it says that I don't have any microphone any input and output devices and driver booster also installed "other devices" like Intel High definition DSP and intel sensor
I really want to make my sound work again.
Hi ,
So, I've used driver booster to optimize my audio, and it installed cirrus logic awesome speaker and another device called intel high definition dsp
I'm using an integrated intel iris xe graphics
I will try revo uninstaller I will tell when I do so
Hi ,
here is the screen shot
and I don't really know how to use revo uninstaller
Hi ,
You will access revo uninstaller, it will load the list of applications and you will remove cirrus logic application and driver booster after that you will download these drivers and install them one at a time.
https://ftp.hp.com/pub/softpaq/sp148001-148500/...
https://ftp.hp.com/pub/softpaq/sp147001-147500/...
Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
Hope this helps.
If you find the answer helpful, please mark it as an answer.
