I don't need endless lists to repair your update **** ups!
I need a one button solution!
You provide this when **** up my pc, what you call updating, so provide it to undo YOUR ****!
Windows 11, "no audio devices found" both input and output. What happened to my speakers in the laptop?
Windows 11, "no audio devices found" both input and output. What happened to the speakers in my laptop?
* Changed to a question
2024-11-23T12:01:08+00:00 -
2024-11-23T12:20:13+00:00 I don't need endless lists to repair your update **** ups!
You provide this when **** up my pc, what you call updating, so provide it to undo YOUR ****!Someone on here asked if I use Norton, and if so revert back to the previous update.
Did exactly that and sound problem solved. Not a Microsoft fault, Norton screwing with my laptop.
I'll be changing when my current account expires, had no end of problems since installing Norton.
2024-11-23T21:50:03+00:00 No funcionan altavoces
Deleted
2024-11-24T06:19:41+00:00 output sound is not coming
