ok il try it again thanks
How do I get my Realtek Audio Driver back on my HP laptop?
How do I get my Realtek Audio Driver back on my HP laptop? It has completely disappeared. It is no longer in the Device Driver to add back or update. Ive tried to find the device driver by going to to device manager there is no audio to choose from and when I go down to the sound it only shows Bluetooth devices that are not in use anymore.
Thank you
Robyn F
2024-11-23T19:17:49+00:00 -
Jonathan Deives 81,435 Reputation points Independent Advisor2024-11-23T19:27:27+00:00 I will await your reply
2024-11-23T21:11:52+00:00 -
Jonathan Deives 81,435 Reputation points Independent Advisor2024-11-23T21:23:52+00:00 See if you can update using the installer you downloaded from manufacturer website
2024-11-23T21:45:45+00:00 Download this audio driver and run it to install
:https://ftp.hp.com/pub/softpaq/sp154001-154500/...
___________________________________________________________
Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
___________________________________________________________Hi, is there any video explanation for the installation for that, if yes, can you please share that. Thank you.
