I chose the troubleshoot option is one of the an option before I do what you said. Plus I don’t think I’ve been getting the spinning dots. But I will pay more attention this time once the repair starts reloading. I’ve gotten so many blue screens I can’t remember now.
How do I get my Realtek Audio Driver back on my HP laptop?
How do I get my Realtek Audio Driver back on my HP laptop? It has completely disappeared. It is no longer in the Device Driver to add back or update. Ive tried to find the device driver by going to to device manager there is no audio to choose from and when I go down to the sound it only shows Bluetooth devices that are not in use anymore.
Thank you
Robyn F
2024-11-26T12:35:48+00:00 -
Jonathan Deives 81,435 Reputation points Independent Advisor2024-11-26T14:19:23+00:00 Select System Restore.
Jonathan Deives 81,435 Reputation points Independent Advisor2024-11-26T14:22:18+00:00 See if you have the point of restoration, if you don't have you will need to repair the computer with a reset this pc option.
2024-11-26T17:14:44+00:00 I selected a date from 11/24/2024. My computer is back up no sound. about to check DM and Settings
No Input or Output Device Found in settings
Just the Bluetooth devices in DM
I still have the Realtek in the DM/action/add leg. hardware/sound/realtek then there are plenty to choose from. however when we got this far last time that when we ran into the your device has ran into a problem blue page
Jonathan Deives 81,435 Reputation points Independent Advisor2024-11-26T17:16:57+00:00 The last solution I know of is HP audio check, a software from the manufacturer to check for sound issues;
https://support.hp.com/us-en/help/computer/soun...
See if the problem persists after using it.
___________________________________________________________
Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
