I downloaded that to
what is the next
I need help. My graphics card isn’t found in Device Manager, replaced by Microsoft Basic Display Adapter with error code 31. Is the card possibly damaged? There should be an NVIDIA GeForce RTX 2050."
2024-11-27T11:43:42+00:00 -
DaveM121 936.1K Reputation points Independent Advisor2024-11-27T11:44:40+00:00 What happens when your try to use that Nvidia drivers installer?
DaveM121 936.1K Reputation points Independent Advisor2024-11-27T12:39:44+00:00 Those are the correct settings you have selected, click the Find button, then try installing a couple of the versions of the Nvidia drivers they provide around the version 561 of the drivers.
