KMODE_EXCEPTION_NOT_HANDLED help?
2024-11-21T07:46:57+00:00
  • <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
  • <System> <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" /><EventID>41</EventID><Version>8</Version><Level>1</Level><Task>63</Task><Opcode>0</Opcode><Keywords>0x8000400000000002</Keywords><TimeCreated SystemTime="2024-11-21T07:37:07.3471937Z" /><EventRecordID>56135</EventRecordID><Correlation /><Execution ProcessID="4" ThreadID="8" /><Channel>System</Channel><Computer>DESKTOP-NV14JER</Computer><Security UserID="S-1-5-18" /></System>
  • <EventData> <Data Name="BugcheckCode">30</Data><Data Name="BugcheckParameter1">0xffffffffc0000005</Data><Data Name="BugcheckParameter2">0xfffff8027a9177e5</Data><Data Name="BugcheckParameter3">0xfffffc888ccbdb18</Data><Data Name="BugcheckParameter4">0xfffff8027e68b920</Data><Data Name="SleepInProgress">0</Data><Data Name="PowerButtonTimestamp">0</Data><Data Name="BootAppStatus">0</Data><Data Name="Checkpoint">0</Data><Data Name="ConnectedStandbyInProgress">false</Data><Data Name="SystemSleepTransitionsToOn">0</Data><Data Name="CsEntryScenarioInstanceId">0</Data><Data Name="BugcheckInfoFromEFI">false</Data><Data Name="CheckpointStatus">0</Data><Data Name="CsEntryScenarioInstanceIdV2">0</Data><Data Name="LongPowerButtonPressDetected">false</Data></EventData> </Event>
I was suddenly gaming when my PC suddenly crashed with the error code KMODE_UNHANDLED_EXCEPTION_CAUGHT. I do not know what caused it.
    2024-11-21T15:00:57+00:00
    What Should I do to re-install the drives, and which one should I use?
    Realtek high definition audio driver ver:9618.1_UAD_WHQL
    AMD chipset driver ver:3.10.22.706
    Realtek Lan driver ver:10039_03232020
    AMD RAIDXpert2 utility ver:9.2.0.158
    SATA Floppy Image_CC ver:9.3.0.296
    SATA Floppy Image_DID ver:9.3.0.296
    SATA Floppy Image ver:9.3.0.158
    VGA driver ver:21.30.02.210727a_0827
    ASRock Motherboard Utility ver:3.0.504
    APP Shop ver:2.0.0.6
    Nahimic3 utility ver:1.9.22_APO3_2
    Norton 360 for Gamers ver:22.22.4.13
    Restart to UEFI ver:1.0.15
    ASRock Polychrome RGB ver:2.0.182
  2. DaveM121 934.5K Reputation points Independent Advisor
    2024-11-21T14:43:37+00:00
    It is the network drivers causing the problem, so those are the drivers you need to re-install, not update.
    2024-11-21T14:41:52+00:00
    anything I should do then once I get there? What drivers should I get from the site?
  4. DaveM121 934.5K Reputation points Independent Advisor
    2024-11-21T14:34:33+00:00
    I think this may be the support page for your motherboard.
    https://pg.asrock.com/mb/AMD/B550M%20Phantom%20...
    ________________________________________________________
    Standard Disclaimer: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
    2024-11-21T14:26:56+00:00
    the part number is 90-MXBI90-A0UAYZ
