Fix Bluetooth problems in Windows
Reported
2025-01-10T18:10:38+00:00
I bought a Discord keyboard and now I can't connect it to my Laptop, it won't work with bluetooth and also not with the cable connection.
Does someone know what I can do?
[moved from de-de]
    2025-01-12T15:24:45+00:00
    plese solved my problem
    2025-01-12T16:40:27+00:00
    Bluetooth can not connect to my pc
    2025-01-12T22:51:12+00:00
    my bluethooth isnt working
    2025-01-13T09:03:27+00:00
    <My windows won't pick up for some reason
    i
    ;; try anoyhrt audio device
    2025-01-13T11:54:49+00:00
    my earbuds are not connecting to bluetooth and my device is also not showing . if i add my device also it is not showing . in control panel it is showing that headphones are not plugged
