BAD SYSTEM CONFIG INFO error
2025-03-04T08:48:15+00:00
Hello, since 2 days ago I have had a bluescreen with the stopcode above, I've tried many different ways to fix it, even went up to install windows 11 twice on the system with no result.
I've got no idea what I need to do or if my system is just done for.
Could someone help or assist me?
Windows for home | Windows 11 | Recovery and backup
  1. DaveM121 933.1K Reputation points Independent Advisor
    2025-03-04T19:47:41+00:00
    Thank you for that information, you do not have an Intel processor, you have an AMD processor.
    I am not sure what driver you need to get the internal drive to appear in the installation on your motherboard model, it would be best to contact Asus support on the support page for your motherboard, they will be able to provide you with the required driver.
    https://rog.asus.com/motherboards/rog-strix/rog...
    ________________________________________________________
    Standard Disclaimer: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
    2025-03-05T10:58:56+00:00
    I'm trying to contact Asus through the support, for some reason the serial that i put in doesnt want to work in the mail. Is there another way to obtain the driver?
  3. DaveM121 933.1K Reputation points Independent Advisor
    2025-03-05T11:00:27+00:00
    The driver Asus support provides for your model will be the only driver that is compatible with your system motherboard.
    2025-03-05T11:19:22+00:00
    I've tried to enter my model and sn which both didn't provide with the correct model as shown. The sn didn't show anything. It seems the B550 model isn't shown in that section.
  5. DaveM121 933.1K Reputation points Independent Advisor
    2025-03-05T11:26:08+00:00
    At the very start of the installation process, press Shift + F10, or Shift + Fn + F10 to open Command Prompt
    Run this command and hit Enter:
    diskpart
    list disk
    Please provide a screenshot of that Command Prompt window.
