I don't think so, I had the folder on one drive the entire time. I didn't use another drive for installation at any point. But why's the unallocated folder gone?
BAD SYSTEM CONFIG INFO error
Hello, since 2 days ago I have had a bluescreen with the stopcode above, I've tried many different ways to fix it, even went up to install windows 11 twice on the system with no result.
I've got no idea what I need to do or if my system is just done for.
Could someone help or assist me?
Windows for home | Windows 11 | Recovery and backup
2025-03-04T19:03:54+00:00 -
DaveM121 933.1K Reputation points Independent Advisor2025-03-04T19:12:20+00:00 When you start the installation now, what partitions do you see on your drive, please provide a photo of that.
DaveM121 933.1K Reputation points Independent Advisor2025-03-04T19:29:42+00:00 Thank you for the image, that is just your bootable USB.
Do you have a modern Intel processor on your PC?
If you do, you need to go to the support page for your PC on the manufacturers website.
From the chipset or storage section section, download the installer for the Intel RST drivers.
Extract out the drivers from that installer and put them into a new folder on your USB.
When you reach the part of the installation where you cannot see the drive to install Windows onto, click 'Load Driver', then select one of those Intel RST drivers, you will then be able to see the drive to install Windows onto.
