BAD SYSTEM CONFIG INFO error
2025-03-04T08:48:15+00:00
Hello, since 2 days ago I have had a bluescreen with the stopcode above, I've tried many different ways to fix it, even went up to install windows 11 twice on the system with no result.
I've got no idea what I need to do or if my system is just done for.
Could someone help or assist me?
Windows for home | Windows 11 | Recovery and backup
    2025-03-06T13:28:09+00:00
    I don't think I see it anywhere.
  2. DaveM121 933.1K Reputation points Independent Advisor
    2025-03-06T13:32:39+00:00
    If you still cannot see the target drive to install Windows onto, most likely, there is a hardware problem with the drive, it would be best to have it tested at a PC Shop.
