BAD SYSTEM CONFIG INFO error
2025-03-04T08:48:15+00:00
Hello, since 2 days ago I have had a bluescreen with the stopcode above, I've tried many different ways to fix it, even went up to install windows 11 twice on the system with no result.
I've got no idea what I need to do or if my system is just done for.
Could someone help or assist me?
Windows for home | Windows 11 | Recovery and backup
    2025-03-05T15:09:50+00:00
    couldnt it be the Intel driver as you stated before? or is this only something adressed to my problem? i could always download what we think the problem is and try it.
  2. DaveM121 933.1K Reputation points Independent Advisor
    2025-03-05T15:10:52+00:00
    It cannot be the Intel RST drivers, because you have an AMD processor.
    2025-03-05T15:19:06+00:00
    There are multiple AMD drivers as shown here. I could try one of them out which sounds closest to the problem's needs.
  4. DaveM121 933.1K Reputation points Independent Advisor
    2025-03-05T15:38:39+00:00
    None of those drivers in those screenshots are the drivers you need, you need to contact Asus support on that website to get the required driver.
    2025-03-05T16:21:45+00:00
    Ive tried to send a mail multiple times, the serial keeps denying for some reason. Ive tried both the processor and motherboard serial. Is there any way you could assist with this issue? I know its more of a me problem but i seriously am not able to send a mail.
