Installation issues
2025-03-03T15:27:13+00:00
I’m trying to reinstall the NVIDIA App but when I run the installer it automatically installs into my D drive and not my local C drive and the app won’t work and I don’t know what else I can do.
I’ve spoke to NVIDIA support with no luck and Microsoft technical support with no luck.
I’m running windows 11 on a desktop and my graphics card is a GeForce GTX 1080.
For some reason when I run the Nvidia app installer it doesn’t give me an option to choose where to install the app and I don’t know why it has all of a sudden decided install apps into my D drive and not my local C drive.
I’ve tried using a new user account, Nvidia full cleanup tool and a complete fresh download of drivers and app but nothing has worked.
And I’m at the point of not knowing what to do, I do have a windows update that needs installing but sadly I don’t have TPM 2.0 so can’t install it.
The app was working at the beginning of last week but because my local C dive was at capacity I needs to uninstall some apps to make space and I did that and have installed everything back on and is working ok apart from the NVIDIA app and Ubisoft connect but I don’t know if the two are related.
Any help would be greatly appreciated as this is driving me insane.
    2025-03-05T11:54:12+00:00
    When I do it. Do I need to back everything up or only specific things?
    2025-03-05T12:00:02+00:00
    It is safer to backup your personal files in case the reset operation goes wrong, a backup of your files is always necessary, one copy of your files is never enough, even in a normal time.
