Hi ,
Open armoury crate > Device tab > select the motherboard > look for the audio option, take a screenshot and post it here
Independent Advisor - Community
hi guys, built a new pc last november, everything was fine and all and i decided to pick up a mic splitter like a month ago so i can use my earphones' mic to talk to my friends while i game, so like i noticed an issue when using the mic where it picks up my desktop audio for some reason, tried to fix it by updating realtek drivers, didnt work, this same issue happened to my acer nitro 5 a year back and that was fixed with a driver update, idk what the problem is and idk how to fix it tbh, anyone know how to fix it? tried to look around the web and its just the same stuff i tried, updating, reinstalling drivers, i dont even know at this point i genuinely feel like hating realtek drivers at this point because of how this issue even happens randomly
Hi ,
Hi ,
You will turn it on and set Realtek as the main microphone only.
Then access the Sound Control Panel again and activate AI noise Cancellation, take a screenshot and post it here
Hi ,
You will keep these two connected in the crated amoura, you will access the audio tab and select the microphone tab and select Realtek as in the image below:
It was accidentally resolved, do not mark it.
