Problem with updating to 23H2
2025-04-12T00:03:58+00:00
Hello! I have a problem that I'm trying to fix for a year and its regarding Windows 11, version 23H2 update. When I download and install it from the WIndows Update everything is fine but when it starts insalling this is where the problem begins. It goes to black screen and the text saying "Update is underway. Don't turn your pc off. Your pc may restart a few times". This is a normal screen appearing everytime you download, but when it gets to the first restart it changes to another windows with different looking text and it stays for a few seconds then it says "Undoing the changes made to your pc". Then when I go into the Window Update I see an "Install error - 0x80248007" . This has appeared everytime I try to update it. I have tried everything that I could find on the internet, chatgpt, the robot chat responder at microsoft, but nothing works and I need somebody to help me with this problem.
2025-04-14T18:54:45+00:00
No need for that i finally did it. I serached on internet for this error message and came upon another forum that talked about the error and all i had to do was type this command in command pront as Admin:
rundll32.exe pnpclean.dll,RunDLL_PnpClean /DRIVERS /MAXCLEAN
Then I had to turn off my wifi and bluetooth before rerunning the setup. I didn't thought it would work but as soon as my laptop restarted the update was stuck on 0% but it actually started at 12% and I was in shock and it did install and now my laptop is up to date. Thank you for all the work that you put to help me! I'm really greatfull and here is the link to the the forum page that I got the solution from, its the first comment under the post: https://answers.microsoft.com/en-us/windows/forum/all/the-installation-failed-in-the-safeos-phase-with/7f910879-39b1-4459-b3e0-abe84208e4d6
127 additional answers
    2025-04-12T06:50:18+00:00
    The laptop has been having BSODs since January 2025.
    Please run the HP UEFI hardware diagnostics as per the prior post.
    If that reports pass after two runs then plan to run Windows Driver Verifier (WDV):
    https://www.tenforums.com/tutorials/5470-enable-disable-driver-verifier-windows-10-a.html
    2025-04-12T06:11:51+00:00
    The Memory Integrity is activated and I’m downloading the update, but I’m writing from my phone because when i try to send a message from my laptop it says Something is wrong Try again
  3. Ramesh Srinivasan 87,350 Reputation points Independent Advisor
    2025-04-12T05:55:16+00:00
    You should be able to delete those drivers using Autoruns.
    Autoruns - Sysinternals | Microsoft Learn:
    https://learn.microsoft.com/en-us/sysinternals/...
    Run Autoruns as administrator.
    Select the "Drivers" tab.
    Find those three driver entries and delete them.
    2025-04-12T05:52:30+00:00
    There is still a problem there are still some driver packages and I cannot find them in the Driver Store Explorer:
