Problem with updating to 23H2
2025-04-12T00:03:58+00:00
Hello! I have a problem that I'm trying to fix for a year and its regarding Windows 11, version 23H2 update. When I download and install it from the WIndows Update everything is fine but when it starts insalling this is where the problem begins. It goes to black screen and the text saying "Update is underway. Don't turn your pc off. Your pc may restart a few times". This is a normal screen appearing everytime you download, but when it gets to the first restart it changes to another windows with different looking text and it stays for a few seconds then it says "Undoing the changes made to your pc". Then when I go into the Window Update I see an "Install error - 0x80248007" . This has appeared everytime I try to update it. I have tried everything that I could find on the internet, chatgpt, the robot chat responder at microsoft, but nothing works and I need somebody to help me with this problem.
2025-04-14T18:54:45+00:00
No need for that i finally did it. I serached on internet for this error message and came upon another forum that talked about the error and all i had to do was type this command in command pront as Admin:
rundll32.exe pnpclean.dll,RunDLL_PnpClean /DRIVERS /MAXCLEAN
Then I had to turn off my wifi and bluetooth before rerunning the setup. I didn't thought it would work but as soon as my laptop restarted the update was stuck on 0% but it actually started at 12% and I was in shock and it did install and now my laptop is up to date. Thank you for all the work that you put to help me! I'm really greatfull and here is the link to the the forum page that I got the solution from, its the first comment under the post: https://answers.microsoft.com/en-us/windows/forum/all/the-installation-failed-in-the-safeos-phase-with/7f910879-39b1-4459-b3e0-abe84208e4d6
127 additional answers
  1. Ramesh Srinivasan 87,350 Reputation points Independent Advisor
    2025-04-13T15:09:46+00:00
    Open the .cab file using 7-Zip. Extract the "lib" folder to the desktop. then move the lib folder to the C drive's root directory.
    2025-04-13T15:08:52+00:00
    where exactly should i put the lib folder because i coundn't understand. In the directory that you told me to screenshot?
    2025-04-13T15:05:12+00:00
    here is the screenshot:
    2025-04-13T15:03:54+00:00
    1. Please reinstall:
    rtwlane Realtek Wireless LAN 802.11n PCI-E Network Adapter c:\windows\system32\drivers\rtwlane.sys
    (download the new driver to a desktop folder before uninstalling)
    1. Create a new restore point
    2. Restart WDV with all customized tests except: [ ] 0x00000004 Randomized low resources simulation.
    If there is no immediate BSOD then open administrative command prompt and copy and paste:
    verifier /querysettings
    Post a share link.
    For any BSOD post a new V2 share link into the newest post.
    Name [00000001] Realtek RTL8822CE 802.11ac PCIe Adapter
    Adapter Type Ethernet 802.3
    Product Type Realtek RTL8822CE 802.11ac PCIe Adapter
    Installed Yes
    PNP Device ID PCI\VEN_10EC&DEV_C822&SUBSYS_85F7103C&REV_00\00E04CFFFEC8220100
    Last Reset 4/13/2025 12:53 PM
    Index 1
    Service Name RTWlanE
    Driver C:\WINDOWS\SYSTEM32\DRIVERS\RTWLANE.SYS (2024.0.10.226, 11.26 MB (11,807,280 bytes), 12/27/2021 10:58 PM)
    rtwlane.sys Fri Dec 24 03:56:56 2021 (61C59968)
