Mapped Drive will not connect after reboot
2020-07-24T15:46:02+00:00
After a recent windows update I have had multiple issues with my network drives on my home network.  Some of these were caused by my router which I have replaced.  Now I have all but one drive working correctly.  I cannot figure out the one remaining problem.
If I map the drive by the name (\MyBookWorld\Public) the map works OK until I reboot.  After reboot, I get the error of "The Specified network name is no longer available".  I cannot connect to drive via start>>run either.  If I try to access the drive by IP address using start>>run, it works.
If I disconnect the map drive and reboot, I can connect from start run to the drive after every reboot.
If I map the drive by IP address, reboot and then try to use the drive, I get "Microsoft Windows Network:  The local device name is already in use".  Net use shows the drive disconnected and has an entry to the unc name.  It works if I use start>>run to the UNC name.
I have verified that smb is enabled on the machine.  I have made sure the services of "comptuer browser", "LanmanServer", and "LanmanWorkstation" are set to automatic start.
I have removed the mapping, made sure that it was not in the net use list in the command prompt and made sure the registries at HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2 for this drive have been removed.
I have added the mapping to the Hosts file.
I tried mapping to a different drive letter and get the same problem.  Any ideas on what in Windows is messing this up?
    2021-01-06T15:49:26+00:00
    Thanks John,
    I had thought about maybe trying a batch file to "remap" the NAS drives at every reboot. However, having not done batch files since DOS days, I didn't know how to proceed. I will certainly try yours, adjusted for my system. But first, how did you arrive at the IP addresses for each network drive? The 192.168 part is clear to me; but how one determines the other two parts isn't. Is it arbitrary, or is there some process to suss out just what they need to be?
    2021-01-06T08:23:04+00:00
    Hi!
    Thank you for the tip.
    My solution with the correction of the date on the NAS only lasted for a few days. :-)
    Got another tip now to use the IP Address to the NAS and not the name, and this has worked today. I'll test it for a few more days to see what happens.
    2020-12-27T06:57:41+00:00
    So, in desperation I logged into my Dlink NAS DNS-345, and did some poking around.
    The clock was off by 15 minutes, as none of the built in NTP's were working anymore. Set the clock to match my computer, reboted the NAS, and for the last three days I have had no problem with the Mapped Drive, after rebooting my PC.
    I also tried to replicate the issue, by resetting the time to the previous faulty time, but I still had access.
    I had tried several reboots of the NAS  earlier without any luck.
    Not sure what really solved the problem or if it will return shortly again or in the future at all...
    2020-12-26T04:08:20+00:00
    The key  HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>CurrentVersion>Policies>System does not exist on my new Win10 PC. The path stops at Microsoft; there is no CurrentVersion and beyond. I have Windows 10 Pro, 1909 version; and Settings tells me it is completely up to date.
    Otherwise, I did the  HKEY_CURRENT_USER >Network>Drive Letter entry. It did not help. I can map a MAS drive to my LAN, using the net use driveletter:  command (as Administrator) with the Persistent:Yes switch  to make the NAS share visible and read/write accessible through File Explorer. After a reboot, the drive is still visible, but no longer read/write accessible. I have come to a complete dead end trying to make my new Synology NAS drive readily available.
    2020-12-17T09:05:49+00:00
    Hi!
    I have tried this several times now, but without any luck.
    Every time I reboot, (cold or not), I still have to disconect network drive and connect to it again in order to be able to access it.
