my pc keep crashing tried many solution nothing worked im still getting black screen/BSOD
2020-09-22T00:47:20+00:00
hello
(before i say anything what u will read right here is the same on a thread i posted before and im doing new post bcs my problem didnt got fixed)
my pc is  still new a year and half now
but for a long time im getting alot BSOD
tried to  fix the issues  with many methodds nothing works i even opened one thread here about the problem and nothing worked for me
and the thing  that its happening to me its soo weird im having the weirdest PC ever
here is whats going on
so i login  to my pc doing work playing games watching youtube etc...
everything fine then BOOM all of sudden my pc crashes and restart by its on
and then everything is fine im it didnt crash anymore
and then i restart my pc  or close it for different reason and then  when i use it everything is fine  then BOOM bsod and its restart and everything is fine after
and also sometimes when i get bsod
there  a precentge to collect information about the crash
sometimes it went 100% and restart everything is fine
but sometimes its stays at 0% and then it restart BUT guess what happen i get black screen this msg i forgot what it said exactly but its something like this ( pls reboot insert a proper boot device ) something like that
but when i reboot by ctrl + alt + del to restart im having the same msg. so what i did i just turn off my pc by
the boot button wait couple of min then boot again and everything is fine again  i login i go do my work THEN BOOM  my pc crashes and restart by its own then it wont crash again incouple of days if i didnt close my pc
so  what i mean by all of this is
when my pc restart by it own there will be no another crashes for couple  of says then it will crash
but when i restart or close my pc annd open it  by my self and then the crashes happen again  until it restart on its own to work fine
and so what i do i just open my pc wait for it to crash and restart by its own and so i work fine without crashes and when im done i keep my pc open so i  dont have to open it by myself and crash all over again
and thats happen to me for long time i was battling with this ****
i just dont know  **** is going on
tried alot of **** nothing works
sry for the long msg
(and   i posted a thread like this before it in here
https://answers.microsoft.com/en-us/windows/forum/all/my-pc-keep-crashing-and-im-getting-alot-of-bsod/eb936ddf-4bec-4476-bb8d-aecf286a107c
or check it on my profile)
and i have gtx 1660ti
i5 9600k
16g ram
ADATA ssd
WDC
    2020-09-27T15:50:45+00:00
    See here what is Intel Optane memory:
    https://www.intel.com/content/www/us/en/archite...
    https://store.hp.com/us/en/tech-takes/what-is-i...
    If you google your PC model specifications it should explain exactly what type of Intel Optane memory you have.
    2020-09-27T09:34:02+00:00
    hello greg Carmack
    how are you doing i hope you are doing ok
    back to business
    i came to ask ya before i contiune isnt the optane  a memory or something?
    bcs i dont recall if i have that in my PC so should enable it either way?
    2020-09-25T17:22:31+00:00
    clean out inside of your computer
    do a disk clean up
    delete your cookies
    scan your computer for spyware.
    2020-09-25T17:21:48+00:00
    It says that you can manage Intel Optane memory using the presently installed Intel Rapid Storage Technology. You dont' need to uninstall that and install Intel Optane Memory.
    I gave you tutorials for how to make sure Intel Optane is enabled in BIOS and then how to make sure it's enabled in Windows.
    If you have any further questions contact your motheboard Support as it is a hardware issue and we deal with Windows here.
    2020-09-25T17:03:01+00:00
    apologies greg but can i have explanation of whats going on
    from what i understand we are talking about the issue when we install the Optane  drivers
    am i right?
    and whats the meanning of this msg
     what is it exactly do u want me to search for it or something?
