From July 24th to today, I have had zero studdering or freezing occur. I cant pinpoint the exact cause but i believe it was bad drivers relating to the PCIe M.2 or SATA controlling the hard drives. My OS is on a M.2. which seemed to be the main issue. IObit Driver Booster updated many of those drivers that Intel or Asus (motherboard) did not give updates for whatever reason. This is just my experience and I have fixed my issue relating to the studder.
System Freeze and Audio Problem
I have just purchased a new computer but as i installed programs, a problem was introduced. I think I had seen the same problem on my previous computer, but that is a long story!
The effect is that the computer freezes for about 5 seconds and then continues. Associated with that is a message from the Realtek Audio informing me I have just plugged a device into the audio input. It does not require there to be any audio playing at the time this happens, though if there is audio, then that either goes silent or issues what can best be described as a buzz until the system resumes. The audio can also go into a state which i can only describe as like a stutter, where maybe it freezes for a few milliseconds at a time over a period of about 5 seconds. Sometimes this produces the Realtek message, though not always.
It seems that sometimes this can be triggered by activity, e.g calling a new web page in the browser. Often on returning to the machine after a period away, where the screen has blanked, waking the system up causes the Realtek message, but no obvious freezing of operation.
But the problem can also occur when the machine is not being used. I can be in the next room eating lunch and hear the audio freeze for the period associated with the problem.
With the new system, I started by sequentially installing the programs I required. This was a processed performed over several days as I was also working on the machine as well. Among the programs I had always installed was OpenOffice, I had been using this since it was first available, though I think generally LibreOffice now does better. But as I installed OpenOffice after several days without a problem, I heard the quality of the sound change and the problem started. On average, the problem manifests itself about once an hour, so i think the initial trouble free period up to the installation of OpenOffice identifies the culprit, but uninstalling it did not help. Windows repair tool claims to identify a problem and to have repaired it, requiring a reboot, but the problem still returns, so something somewhere is damaged. Google does nothing but confuse attempts to find the Realtek drivers which could be reinstalled.
I don't know where to go. I can't believe I am the only person suffering from this problem, yet I cannot find reference to such a problem on Google. So this is my last ditch effort to solve the problem before resorting to a clean install.
Regards, Paul Dixon
2020-08-07T14:45:17+00:00 -
2020-06-10T21:13:30+00:00 Hi, all.
I have same issue on my win 10. I also have asus motherboard so maybe it's MBO related problem? I don't know but it is very frustrating.
2020-06-04T18:34:11+00:00 While I am still testing hardware I am really thinking this is a Windows problem. I am running Windows 10 version 1909 which is fully updated. Also I get this problem just playing Solitaire which is connected to the internet but I don't need to be watching video with or without music. I have not been playing any serious games because of this problem. I have tried Installing my extra programs very slowly and testing between them to see if they have caused this but so far they seem to not make a difference. Just out of hand are you using WIFI or LAN to connect to the internet ? Perhaps this is caused by the way each is handled by windows.
2020-02-12T02:01:44+00:00 I am glad to help, Paul.
Keep me posted on your progress as I will be here to help until the case is resolved.
2020-02-12T01:27:58+00:00 Hi Greg
Thanks for your response and suggestions.
Quite a list there. I am out tomorrow, so it may be Thursday before I can get onto doing this, but I will get back and let you know if it has been successful.
Regards, Paul
