System Freeze and Audio Problem
2020-02-11T18:37:30+00:00
I have just purchased a new computer but as i installed programs, a problem was introduced. I think I had seen the same problem on my previous computer, but that is a long story!
The effect is that the computer freezes for about 5 seconds and then continues. Associated with that is a message from the Realtek Audio informing me I have just plugged a device into the audio input. It does not require there to be any audio playing at the time this happens, though if there is audio, then that either goes silent or issues what can best be described as a buzz until the system resumes. The audio can also go into a state which i can only describe as like a stutter, where maybe it freezes for a few milliseconds at a time over a period of about 5 seconds. Sometimes this produces the Realtek message, though not always.
It seems that sometimes this can be triggered by activity, e.g calling a new web page in the browser. Often on returning to the machine after a period away, where the screen has blanked, waking the system up causes the Realtek message, but no obvious freezing of operation.
But the problem can also occur when the machine is not being used. I can be in the next room eating lunch and hear the audio freeze for the period associated with the problem.
With the new system, I started by sequentially installing the programs I required. This was a processed performed over several days as I was also working on the machine as well. Among the programs I had always installed was OpenOffice, I had been using this since it was first available, though I think generally LibreOffice now does better. But as I installed OpenOffice after several days without a problem, I heard the quality of the sound change and the problem started. On average, the problem manifests itself about once an hour, so i think the initial trouble free period up to the installation of OpenOffice identifies the culprit, but uninstalling it did not help. Windows repair tool claims to identify a problem and to have repaired it, requiring a reboot, but the problem still returns, so something somewhere is damaged. Google does nothing but confuse attempts to find the Realtek drivers which could be reinstalled.
I don't know where to go. I can't believe I am the only person suffering from this problem, yet I cannot find reference to such a problem on Google. So this is my last ditch effort to solve the problem before resorting to a clean install.
Regards, Paul Dixon
    2020-10-10T22:35:06+00:00
    As I am still stable without all these extra things people are doing and or claiming, I repeat I did a fresh install of windows 10 and was very careful of installing all the windows updates before I used the Intel driver update tool and also then the manufactures motherboards drivers. It has been a while now that I have been stable without any problems. I do not believe this problem has anything to do with what system you built! I think it is a windows driver conflict with an Intel driver. As this is not widespread they may just fix it in an update and never admit to this problem. I really think its all how you install your drivers. If anyone can talk to this please do so.
    2020-09-22T16:47:34+00:00
    If you have your system installed from m.2, try to install it on a normal drive. for me, that was the problem.
    2020-09-22T16:37:33+00:00
    Hi to all who are still suffering from this issue. I have been facing with exactly the same issue for a while. I seem to have fixed it by changing the power plan to be as performance-oriented as possible. Never sleep; never turn off display; hard disk is turned off after 200000 minutes; etc. So far the problem is gone for one entire day.
    2020-09-20T21:29:52+00:00
    An update for everyone.
    About 2 weeks ago I updated the BIOS of my Asus motherboard. I began getting the studdering occuring again. So I went into the BIOS, reset all the settings to default, Set XMP profile on my memory, Checked the onboard settings, Changed M.2 Mode from Auto to PCIe. Changed SATA Controller from Intel Optane to AHCI. Saved and restarted. Computer seems to be more stable now. I have a total of 5 hard drives in my computer. M.2 runs the OS, 2TB HDD for Games, 4TB HDD + 500GB HD Dynamic Spanned as my Network Storage drives, and a 500GB SSD that is Initialized but Unallocated. The combination of the drives and motherboard M.2 and SATA controller could have very well been the issue for me this time.
    2020-08-24T12:08:40+00:00
    Do you have your system on an nvme n.2?
