Wireless bluetooth earphones keep disconnecting...
2019-11-27T12:53:47+00:00
I bought Realme buds wireless bluetooth earbuds recently. I started using them with my phone and it worked just fine. But when I used it with my laptop (Asus FX570UD) it works for sometime and then automatically disconnects and the same problem persists when I reconnect it again. I tried troubleshooting but it is of no use. I need help with why it keeps disconnecting frequently??
2020-01-30T06:40:45+00:00
no, it didn't work for me. because when you uninstall Bluetooth driver , windows automatically install a new one.
Windows will do that automatically as when you uninstall in the device manager, the driver has not been removed from the root. I faced a similar problem as Realtek driver used to reinstall after rebooting. So used a third part utility to uninstall: https://www.driverscape.com/download.
Driverscape utility worked for me to uninstall the system Realtek bluetooth driver from root. After I rebooted, windows installed the Microsoft Generic bluetooth adapter, which works perfectly with realme buds wireless. Try this method to uninstall and let me know if it worked for you.
63 additional answers
    2020-01-04T20:00:05+00:00
    I bought them and they worked fine the first day, and now im getting same problem with my PC. they just disconnect in few seconds after pairing
    bought realme wireless bud for its 12 hour battery life now feeling that i wasted my money
    2020-05-27T10:20:42+00:00
    I am also facing the same problem with realme earbuds in my HP Pavillion with Windows 10.
    2020-01-05T04:57:57+00:00
    Same was the issue with mine too
    2019-12-12T04:33:35+00:00
    i think i found a solution for this. i will tell you what i did....
    1. First turn on airplane mode.
    2.  Now, Start Bluetooth.
    1. Search for new Bluetooth device.(Note: - Firstly remove realme already installed driver.)
    2. Now, connect to the realme Bluetooth.
    3. Turn off airplane mode and enjoy the music.
    Nah Didn't work for me though
