Wireless bluetooth earphones keep disconnecting...
2019-11-27T12:53:47+00:00
I bought Realme buds wireless bluetooth earbuds recently. I started using them with my phone and it worked just fine. But when I used it with my laptop (Asus FX570UD) it works for sometime and then automatically disconnects and the same problem persists when I reconnect it again. I tried troubleshooting but it is of no use. I need help with why it keeps disconnecting frequently??
2020-01-30T06:40:45+00:00
no, it didn't work for me. because when you uninstall Bluetooth driver , windows automatically install a new one.
Windows will do that automatically as when you uninstall in the device manager, the driver has not been removed from the root. I faced a similar problem as Realtek driver used to reinstall after rebooting. So used a third part utility to uninstall: https://www.driverscape.com/download.
Driverscape utility worked for me to uninstall the system Realtek bluetooth driver from root. After I rebooted, windows installed the Microsoft Generic bluetooth adapter, which works perfectly with realme buds wireless. Try this method to uninstall and let me know if it worked for you.
63 additional answers
    2020-07-24T16:39:47+00:00
    bro after seeing your solution i bought the same csr 4.0 dongle from a local shop but issue is not resolved.. infact my earphones are getting completely disconnected after 5 to 10 minutes.. i am frustrated with this issue :(
    2020-07-15T07:18:17+00:00
    facing the same problem with lenovo legion Y530. Its first time with any Bluetooth headset device.
    2020-06-30T08:15:48+00:00
    Hello Lohit, your issue is resolved or not. if resolved then suggest me how u have resolved i'm also facing same problem.
    2020-06-30T08:11:11+00:00
    i dont have rolling option. what should i do now?
