Creative SB Audigy 2 ZS driver issue - NO SOUND- after Windows 1903 update
2019-04-30T16:57:58+00:00
Just updated to 1903, and have lost all sound,I know it's old soundcard, but it was working perfectly on build 1809/1803/1709/1703/1607..
2019-06-02T20:38:50+00:00
Hi!
This worked for my Creative Audigy 2 ZS and Windows 10 1903 update:
https://extreme.pcgameshardware.de/windows-7-8-1-und-10-windows-allgemein/540331-win-10-update-1903-soundblaster-kein-ton.html?highlight=audigy
Download "Audigy RX Driver" from Creative
Extract all files
Go to the folder "Audio\DriversWin10\wdm"
Right-click "wdma_emu.inf" and select "install"
Restart and enjoy!
Best regards!
Markus
73 additional answers
    2020-04-18T20:09:29+00:00
    Worked for me! Thanks so much Markus!!
    2020-04-06T10:34:26+00:00
    Hello, I have been looking for a solution for the audio card problem for quite some time, you just made me the happiest guy on earth because I have been able to use my audio card again, really thank you very much!
    2020-04-05T01:03:43+00:00
    Great!! First time I was able to actually post help instead of asking for it and it was helpful to you.  That's cool.
    2020-04-04T18:47:34+00:00
    Thank you for sharing this info. I nearly scrapped a perfectly good card and front bay!
    Worked a treat!
