minidump and events https://1drv.ms/u/s!AszrGIm2cM6CeRwd38amAWq8e5E
:( Your PC ran into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA
I have a problem when I started using a new graphics card gts 750ti restarts my computer and shows: (Your PC has run into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA does not always write PAGE FAULT IN NONPAGED AREA, but this is most often written, also This also shows when I restart my computer, when I remove the graphics from the computer I do not have this problem, I tried with a new graphics card, I still have a problem, do you have any solution? thanks
2018-12-08T09:54:09+00:00 -
2018-12-08T09:38:04+00:00 I tried it all before this, maybe the real problem is the motherboard or the power supply? I do not know why when I remove the graphic I do not have this problem and I know it's not graphic because I tried two
2018-12-08T09:34:56+00:00 I tried it all before this, maybe the real problem is the motherboard or the power supply? I do not know why when I remove the graphic I do not have this problem and I know it's not graphic because I tried two
2018-12-08T09:30:43+00:00 Did you get dumps?
A. Try to boot into safe mode
Power ON your computer and as Windows / manufacturer's Logo appears, Power OFF - Repeat 3 times
Now your computer will go into Advanced Recovery Environment
Advanced Options > Troubleshoot > Advanced Options > Startup Settings > Restart
Press 4 or F4 to enable Safe Mode (5 or F5 to enable Safe Mode with Networking)
Log in once Windows starts in safe mode
See whether you able to login. If yes, come out of this and start normally.
If you are not able to boot like above, You will need to boot through a Bootable USB drive. You will need to create this on another computer which is working - https://www.tenforums.com/tutorials/2376-create...
How to Boot from a USB Flash Drive in Windows 10 - https://www.tenforums.com/tutorials/21756-boot-...
B. Another option when you are in Advanced Options in previous step is to choose (Note - You won't lose any files in this step)
- System Restore - This will restore your system to a point when things were working fine.
OR
- Startup Repair - Startup Repair upgrade fixes all Windows errors and retains all files, applications and settings.
C. Last could be Reset this PC.
In Step A > Troubleshoot > Reset this PC - Keep my files and Remove everything. Choose this carefully as most likely you would like to keep your files.
All apps will be removed and windows will be reinstalled.
Do let me know if you have any more question or require further help. I would be happy to work with you to take you though this problem.
Disclaimer - This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
2018-12-08T09:28:59+00:00 I went into the safemode and came out of the safemode by restarting the computer, then when I came out of the safemode I again restarted the computer once more and PAGE FAULT IN NONPAGED AREA
