Again, the same thing happens, I have not done the last step, now I will, this is minidump https://1drv.ms/u/s!AszrGIm2cM6CdZByhUfcp7EjTZw and this Event https://1drv.ms/u/s!AszrGIm2cM6CdOe77oPS98p2P-0
:( Your PC ran into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA
I have a problem when I started using a new graphics card gts 750ti restarts my computer and shows: (Your PC has run into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA does not always write PAGE FAULT IN NONPAGED AREA, but this is most often written, also This also shows when I restart my computer, when I remove the graphics from the computer I do not have this problem, I tried with a new graphics card, I still have a problem, do you have any solution? thanks
2018-12-08T08:33:01+00:00 -
2018-12-08T08:32:48+00:00 Again, the same thing happens, I have not done the last step, now I will, this is minidump https://1drv.ms/u/s!AszrGIm2cM6CdZByhUfcp7EjTZw and this Event https://1drv.ms/u/s!AszrGIm2cM6CdOe77oPS98p2P-0
2018-12-08T07:22:42+00:00 I'm currently on the 4th and the other steps
2018-12-08T07:21:46+00:00 I'm currently on the 4th and the other steps
2018-12-08T07:17:01+00:00 It may be a problem. Can't be said conclusively as you will need to watch you system and see whether BSODs are still happening or not.
