you sir are my hero
High Definition Audio Controller (Code: 10) Issue
Motherboard: MSI B360M Gaming Plus
OS: Windows 10 Pro
List of things I've done:
Downloaded audio drivers from MSI website
Updated my BIOS
Uninstalled and Reinstalled the High Definition Audio Controller
cmd commands: sfc /scannow & DISM.exe /Online /Cleanup-image /Restorehealth
Completely removed all other audio drivers and installed Realtek audio drivers (Which for some reason never actually appear on device manager?)
I'd appreciate any help I could get.
It started happening out of the blue; I never downloaded anything.
2020-05-19T23:14:36+00:00 -
2020-03-26T08:15:29+00:00 I can't believe it - I spent all day trying to figure out the solution to "No Input or Output Audio Devices" for Windows 10 after an update. I kept being told to reinstall drivers and nothing worked.
Bizarrely, uninstalling my Sound Device from Device Manager as well as the HD Audio Controller and holding power for 50 seconds with the cord unplugged worked!
2020-03-10T19:06:33+00:00 I followed your instructions to the letter. It worked first time after two evenings spent trawling through the internet and attempting various fixes. Thank you.
2019-11-26T16:21:55+00:00 Many thanks, it works for me !!
2019-11-18T00:58:28+00:00 Thanks so much. I have been battling this problem for over a week. Your solution worked!
