Thank you very much! I solve my problem!
High Definition Audio Controller (Code: 10) Issue
Motherboard: MSI B360M Gaming Plus
OS: Windows 10 Pro
List of things I've done:
Downloaded audio drivers from MSI website
Updated my BIOS
Uninstalled and Reinstalled the High Definition Audio Controller
cmd commands: sfc /scannow & DISM.exe /Online /Cleanup-image /Restorehealth
Completely removed all other audio drivers and installed Realtek audio drivers (Which for some reason never actually appear on device manager?)
I'd appreciate any help I could get.
It started happening out of the blue; I never downloaded anything.
2020-06-03T05:30:51+00:00 -
2020-04-25T12:33:31+00:00 I made an account just to comment on this. Happened to me this morning whilst using the laptop (MSI) normally. The whole device froze.
I did all the standard troubleshooting and the first piece of advice was unhelpful (mainly because the "expert" doesn't follow up in the thread). Nothing worked.
Tried the above and it's fully resolved! Was panicking that I would need to send the laptop back, especially whilst isolated would become troublesome and leave me without my gaming device.
Thanks so much.
2020-04-07T15:33:25+00:00 FINALLY a solution that works, I can't believe it was that simple!
I even reset my computer to factory settings because every solution i tried for the past 8 hours didn't work. The same issue persisted after the reset.
I am still PISSED about it.
Thank you so much for putting up this solution, you are a Godsend. Bless you!
2020-03-30T05:38:39+00:00 I tried many many things.
Solution that finally worked for me (don't skip any steps):
- Open device manager and Uninstall High Definition Audio Controller.
- Shut down (not restart).
- Unplug the power cable.
- Press and hold down the power button for 60 seconds.
- Plugin and turn on the laptop.
I made an account just to **** thank you. Dude I was stuck on this **** for a good 1-2 days. Legend!
