bsod kernal power failure bugcheck code 159
2015-05-16T16:40:34+00:00
Hope someone can help caught a blue screen this morning . I have a ASUS laptop Model g73jw.  this is the info from the crash Can Someone Please help
MIke
Log Name:      System
Source:        Microsoft-Windows-Kernel-Power
Date:          5/16/2015 10:03:18 AM
Event ID:      41
Task Category: (63)
Level:         Critical
Keywords:      (2)
User:          SYSTEM
Computer:      mikes-pc
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
< Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
    <EventID>41</EventID>
    <Version>2</Version>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000002</Keywords>
    <TimeCreated SystemTime="2015-05-16T15:03:18.836807600Z" />
    <EventRecordID>419399</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="8" />
    <Channel>System</Channel>
    <Computer>mikes-pc</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="BugcheckCode">159</Data>
    <Data Name="BugcheckParameter1">0x3</Data>
    <Data Name="BugcheckParameter2">0xfffffa800bfafa00</Data>
    <Data Name="BugcheckParameter3">0xfffff80000b9a518</Data>
    <Data Name="BugcheckParameter4">0xfffffa80105cd3d0</Data>
    <Data Name="SleepInProgress">false</Data>
    <Data Name="PowerButtonTimestamp">0</Data>
  </EventData>
< /Event>
2015-07-13T11:02:56+00:00
Mike
Logitech M510 – Do you have the latest drivers?
http://support.logitech.com/product/wireless-mouse-m510#download
Testing to see if the Event 17 warnings stop may take a time judging by the frequency in which they are reported. Otherwise I think all that should be done is to wait and see if another blue screen error occurs. I do not think that reinstalling Windows is justified.
43 additional answers
    2015-05-27T01:35:34+00:00
    Good evening Gerry-
    all tasks complete and here is the link
    https://onedrive.live.com/redir?resid=72040ac237b79dd5%21105
    its interesting that you had me uninstall MacAfee I've had some issues with them in the past but they keep the bugs out so I try not to complain too much.  The malewarebytes is the free version (they keep wanting me to renew).
    Thanks for all the help so far
    Mike
    2015-05-26T10:34:21+00:00
    Mike
    It would appear that you have conflicting security software.
    Is your Malwarebytes the Pro (Premium) or Pro version?
    You need to remove McAfee as it is damaged. Please don’t reinstall for now whilst investigation is being undertaken.
    McAfee removal tool
    http://service.mcafee.com/FAQDocument.aspx?id=TS101331
    How to uninstall SiteAdvisor:
    http://service.mcafee.com/faqdocument.aspx?id=TS100162
    Please download and run ADWCleaner and upload a copy of the report produced to your OneDrive. Remove all that it finds. :
    http://www.bleepingcomputer.com/download/adwcleaner/
    I suggest you take the precaution of creating a system restore point before running ADWCleaner, to guard against unforeseen consequences. Select Start, Control Panel, System, System Protection, and click the Create button.
    To identify what loads when you boot use Autoruns (freeware from Microsoft).
    http://technet.microsoft.com/en-us/sysinternals/bb963902
    With Autoruns you can uncheck an item, which disables it from starting, or you can right click an item and then delete it. If you uncheck you can recheck to re-enable the item. It is a much safer approach than editing the Registry and better than using msconfig.
    Run Autoruns and select the Everything tab. Click File, Save and, using the scroll to the right, change the “Save as type” option from Autoruns Data (*.arn) to Text (*txt). The file name changes to AutoRuns.txt. Click the Save button and upload the file to your OneDrive as a shared file and post as a link here.
    2015-05-26T00:35:48+00:00
    Gerry-
    got the info that you are looking for and I changed the settings like you had asked. FYI it crashed again same code first time this happened since I started this post. Not too sure if you needed the link again so here it is just in case
    https://onedrive.live.com/redir?resid=72040AC237B79DD5%21105
    Mike
    2015-05-21T05:57:36+00:00
    Mike
    Your dump files was over 1gb. Too large to handle. In most situations it is preferable to configure the computer to produce a kernel memory dump when system failure occurs. A complete memory dump is a very large file to handle so it is more practical to work with Kernel memory dumps when trying to resolve blue screen errors.
    Please change your dump files settings to produce a Kernel memory dump. Select Start, Control Panel, System, Advanced system settings, Advanced tab, and click the Startup Recovery Settings button. Under System failure check the boxes before Write an event to the system log and Automatically restart. Change the Write debugging information option using the scroll to the right to Kernel memory dump. Click OK and, in the next window click Apply and OK. Restart your computer to apply the changes.
    Please upload and share with everyone copies of your System log and your Application log (two files) from your Event Viewer to your OneDrive and post a link here.
    To access the System log select Start, Control Panel, Administrative Tools, Event Viewer, from the list in the left side of the window expand Windows Logs and select System. Place the cursor on System, select Action from the Menu and Save All Events as (the default evtx file type) and give the file a name. Do the same for the Applications log. Do not provide filtered files. Do not place the cursor in the list of reports before selecting Action from the menu. Do not clear logs whilst you have a continuing problem.
